Question about Dell Computers & Internet
Dell inspiron+Blinking lights=dead battery?
For weeks now I've been seeing the blinking lights, and a battery slowly drain to zero. I couldn 't figure out why my battery wouldn't charge? I've had my computer about 2 yrs (or so), and never used it without the AC adapter plugged in. I pulled out the battery, turned my computer on and finally no more flashing lights! So...my question is; do batteries sometimes just die because they're old? And then, after I replace the battery, should I pop it in only when not using AC power?
  • Dell Master
  • 3,051 Answers
Hello there:
yes laptop batteries do die over time depending on the use of them so i would first check and make sure that the power cord is working than if so than yes get a new battery.
and the battery should stay in the laptop to help keep the cmos battery on the motherboard charged ok?
hope that this is helpful for you
best regards mike
Posted on Jul 31, 2009
Testimonial: "WOW!Just got my new A/C Adapter and the minute I plugged it into my computer the battery showed it was charging! Thanks a million!"
SHOULDN'T MY BATTERY LAST MORE THAN A WEEK
Do you mean that it goes dead after sitting a week or goes dead after a week while driving it?
Dec 23, 2014 | Cars & Trucks
Battery drain overnight on pontiac 1994sunbird
The alarm light will not kill the battery. Your diode in the alternator may be bad. This will slowly drain the battery. Replace the alternator. Or charge it up and go to auto parts store and have them test the battery and alternator and starter.
Oct 11, 2017 | 1994 Pontiac Sunbird
1991 cavalier rs battery will charge up fine (its new) but it drains down completely in less than a week. The alternator is charging fine. I have had problems with the ignition switch in the past. Could...
Check at night time if all your lights are off like glove box and trunk by opening slowly to see light come on and dash lights and dimmer. try radio with ignition off. it should not work. Underhood light?
May 03, 2014 | 1992 Chevrolet Cavalier
Electrical problem on 1996 Dodge Dakota
It will drain at a rate of 21Watts X 2 = 42Watts at 12Volts = 3.5Amps. If you have an 70 Ah battery that is 20hours to totally flat from fully charged.
May 27, 2017 | 1996 Dodge Dakota
Battery light won't change colors, drops to 0% once unplugged
Let the battery completely discharge all they way and let it sit for a day or so. Some times when a battery is new most user do not let it fully charge and then completely drain this causes problems for long use batteries. Then give it a try. It also sounds like your plug your cord that connects to the battery may be faulty. Did you by a different cord with the battery? Or use the one from your old one? If you did. This is a "No No" always buy the cord that come for those battery since they are rated for the particular battery.
Feb 25, 2012 | Fujitsu LifeBook A1110 Notebook
Battery fully charged, bike turned on after, but on 2nd try after couple of hours, no power
Based on what you've said here I would say that either the battery is incapable of maintaining a charge or something is draining the battery. To test to see if something is draining it, disconnect the positive cable and put an ameter between the cable and the battery to see what current is being 'used' when the ignition switch is off. It should read ZERO amps. If there is current flowing then something is draining the battery - pull fuses to find the culprit. If the drain shows ZERO amps then it's possible the battery is tired and needs to be replaced. Motorcycle batteries don't usually last more than a few years.
I hope this helped. Sorry for any typos.
Scott
Nov 15, 2011 | Motorcycles
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
Hi, my ZEN vision m: does not start anymore; when charging the blue light just "flickers", but even after 1 night charging, no possibility to get to the menu
The rapid-blinking blue light means that the Zen's battery is too drained to allow the player to turn on.
It can take 24 hours or more to completely recharge the Zen using USB. If you see the blue light blinking slowly when you plug it in, then the player is charging, and you will have to wait for it to finish charging.
If, after leaving the Zen to charge for more than a day, it still does not turn on, then the battery may be defective and not able to be charged anymore. The battery will have to be replaced.
May 16, 2010 | Creative Labs ZEN Vision:M Digital Media...
My canon fs 100 doesn't turn on
I took the camera to the representative and we started various tests such as:
Tried My battery in OTHER camera .... not working
Tried OTHER battery in MY camera .... works
Tried charging MY battery in OTHER Camera .... works
Tried MY battery in MY camera and charged .... worked
Bottom end is that my charger is not working although it heats when "charging".
Now i will look at the pins in the charger to see if they are working or not.
Whatever the case .... getting a new charger.
May 29, 2009 | Canon FS100 Flash Media Camcorder
Digital camcorder problem
there a short line to the carbon wire of the function switch.....unfold the wire to loose the fold....and clean the contact of the wire using a pencil eraser slowly
Oct 14, 2006 | Sony Handycam DCR-HC40 Mini DV Digital...
Computers & Internet Logo
321 people viewed this question
Alun Cox
