Question about Kenmore 57029 Side by Side Refrigerator
My kenmore model # is 50569991/ I need a kickplate
My kenmore model # is 50569991 and I need a kick plate...any ideas? Having a hard time locating one.
3 Suggested Answers
  • 85 Answers
SOURCE: I have a kenmore dishwasher but no kickplate. How
Hello cantrell_m,
Sears appliance parts can supply you with the part you need. You will need to provide the model #. Here is their phone # (800) 252-1698.
I hope this is helpful for you. Positive feedback for me is appreciated. Thank you! NormanZ
Posted on Jul 14, 2009
  • 1116 Answers
SOURCE: Mother-In-Law has a Sears-Kenmore Model
Most newer models have a low shank or use the snap-ons as you probably have already run into.
This one is for the older models with a high shank. http://www.sewingmachinesplus.com/5555.php
Posted on Mar 14, 2010
Where is the filter located on a whirlpool refrigerator model ED25TQ
The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will take a little bit of force. Yes this filters the water in the door.
May 14, 2016 | Whirlpool Refrigerators
Help. I have a model # 58717245 portable Kenmore dishwasher. how do I remove kick plate to find out where leak is coming from?
Just remove the 2 screws located on both sides of the toe-kick plate. If it uses the new plastic fasteners, you just turn them 1/4 turn CCW (so the slot is up and down), and then pry them out.
Mar 17, 2015 | Kenmore Dishwashers
Where can I locate the model number? It is no
Is the refrigerator a Kenmore? Some have model numbers located on the wall between the fresh food section door and the kick plate. Most have the model number around the fresh food compartment door frame Kenmore model numbers look like this=> 321.45678 I am here if you have questions or comments, Sea Breeze
Aug 21, 2013 | Kenmore Refrigerators
Where is the model number for the kenmore smart reach refrigerator
Here is a Model Number 596.71813101. Tis is a bottom freezer I am pretty sure. Most of the time the are located in the top section(fresh food section). Open the door(s) and look straight to the top. If not there pull drawers and check on side walls. Last place would be if you open the freezer door it may be located right above kick plate on refrigerator lower frame. Sorry there are so many possibilities but kenmore slaps there name on other manufacture products. Good luck and you can contact me at Apco Appliance and Air anytime.
Apr 04, 2013 | Kenmore Refrigerators
Remove kick plate
Tip the unit back and put your hand under each side in turn underneath, the kickplate is held on via clips near each front foot (the retainer lug is part of the kickplate) this will release it. To reinstall offer the kickplate up under the door panel and give the bottom a push to relocate the clips.
Mar 19, 2013 | Bosch SMS68M02AU Dishwasher
Replacing defrost timer,needs manuel
I check there is no free manual for Kenmore, I find. Better follow these steps to replace defrost timer.
Unplug the refrigerator. Locate the defrost timer. The timershould have four metal terminals coming from the bottom of the unit. It isusually situated behind the refrigerator, in the refrigerator's control panel,the freezer compartment toward the front of the cabinet or behind a metal kickplate on the bottom of the refrigerator. Older Kenmore models may have it builtinto the ice maker. Remove the defrost timer by takingoff the kick plate (if there is one) and removing any screws attaching it tothe refrigerator or freezer. Carefully pull the timer out from the wall of theunit so you can disconnect the wiring from the connectors. If removal isdifficult, try wiggling the connectors back and forth to help loosen them andpull on them firmly. Plug the wire connectors into thenew defrost timer and replace the timer in the refrigerator. Secure with screws, replace coverand plug in refrigerator.
Thanks and helpful?
Jan 23, 2011 | Kenmore Side by Side Refrigerator
Location of model & serial number on a Kenmore 20 porcelian plus unit. This is a older frig.
Most common spot is down where your kick plate is. Remove your kickplate and look for a metal or metallic looking model number plate. If not there then pull your crispers out and look at the side walls inside the refer section. Finally on some models look at the ceiling in the refer section. Good Luck, Appliance Specialists
Dec 31, 2009 | Kenmore Refrigerators
Location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
May 17, 2009 | Whirlpool ED2FHEXN Side by Side...
Where's the condencer?
there is a fan located under and behind the fridge. there is a condensor under the fridge behind the front kick plate the fan is used to circulate the air trew the condensor . remove the kick plate at the botom of the fridge and using a vacume with a crevace tool klean the dust out of the condensor..
hope i was able to help. post feadback if so
Oct 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 57029 Side by Side Refrigerator Logo
120 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
