Question about Pyle Televison & Video
I can't change FM stations on my Pyle Audio PDA6BU receiver. Can you Help?
The CH- and CH+ buttons on the remote do nothing but the remote will turn the unit on and off and change Mode. I am using the antenna supplied by Pyle Audio.
    Master:
  • 430 Answers
The silver buttons on the top left. The one to the right of "Mode" ... the 'fast fwd' symbol. That will cause the receiver (when in radio mode) to scan the FM "dial" and lock in perceived or real stations. Thirty is the limit I think. You can't tune individual stations so the next best thing is to get a better quality Antenna to bring in more stations (do it at night) on the scan (which can always be repeated). Also, be sure to get the Female version of the antenna connector.
Posted on Mar 04, 2018
  • 4 Answers
You TV Player is very popular app design for watching online videos and downloaded videos on the smartphone. It is a similar version of the YouTube app for Android, iOS & PC. Many users ask me for alternative a YouTube, Well You TV Player App is the dominant video player Social Streaming. You TV Player Apk App Pro Download For Android PC iOS
Posted on Sep 05, 2018
SOURCE: Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Posted on Feb 02, 2007
relectronics
  • 38 Answers
SOURCE: AM/FM receiver
the problem is in your tuner for me it is betwen the IC and the IF transformer. if u cant fix it buy new stereo componet.
Posted on Apr 18, 2007
  • 520 Answers
SOURCE: Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
Posted on May 15, 2008
SOURCE: XM Roady2 Built in FM Modulator not working
It's not in the menu selections because the Roady 2 does not have an internal FM transmitter. The Roady XT does though.
Posted on Jul 07, 2008
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Posted on Aug 07, 2008
How can i use the remote to play fm again cos it stop working suddenly and start showing PRE 1-15 If i want to press the tuning/ch bottom
You may have to repeat the station preset process. Your unit is prompting you to select a preset station in the 1-15 range.
Feb 11, 2017 | The Audio Players & Recorders
Sound used to be clear. Now have static. Is my pyle PT54 digital tuner bad? I also get a loud hum when the unit is tunred off.
Sorry, but Pyle isn't good gear. If you've checked all the wiring and nothing else has been altered then I'd point the finger at the Pyle-o-c***
Sep 03, 2014 | Pyle New-Home Pt504 Rack-mount Am/fm...
How do I set the clock on my Pyle PLR34M mobile audio system?
press and hold DISPLAY button until numbers start blinking on display screen use volume knob to change numbers press volume knob to switch from hours to minutes press DISPLAY when done
Jul 11, 2014 | PYLE Audio NEW PYLE PLR34M IN DASH USB SD...
Radio tuning
PIONEER VSX-D903S - A/V Receiver
PIONEER CU-VSX079 - Remote
Here's the basics: Make sure your receiver is in the Tuner mode, by selecting Tuner on either the remote (grey button), on the receiver, or from the GUI menu. (The display will also show TUNER.) There are a couple of different ways to tune a station. One method is with the remote. Use the Band button on the remote (or via the GUI display), or the FM/AM button on the receiver, to select the frequency type. Use the Freq/Ch buttons on the remote to tune, the number buttons for presets (30 presets total. Examples: Preset 5, simply press 5; Preset 15, enter 5-5; Preset 25, enter 5-5-5). You can also use the on-screen GUI menu and the remote to tune stations, using the lower grey buttons. If you want to tune directly, via the receiver, press Select, to switch between frequency tuning and presets (displays ST CALL) mode. Use the Multi-Jog dial to make your selection in either mode. The easiest way to program a station into a preset is to use the onscreen GUI menu. [NOTE: The GUI mode (TV Monitor Video Out, composite video) is active when an amber (orange) ring glows around the Multi-Jog dial (the GUI button on the receiver will also glow simultaneously). Use the remote lower grey buttons, or use the Multi-Jog dial and Select, to move the cursor and select commands on the TV. This A/V Receiver handles composite video/S-video, and Stereo/Dolby 3-Channel/Dolby Pro-Logic audio only. (Pre-ATSC/HD video, Pre-Dolby Digital/DTS multi-channel surround audio)]
Feb 07, 2014 | Pioneer VSX-D903S Receiver
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
Could someone please help me with the 3-digit remote control code for my Pyle Pro P1001AT amplifier?
Since the code is generated by the REMOTE, it would help to know the BRAND of remote you plan to use. The code is not generated by your pyle amp
Mar 11, 2013 | PYLE Audio PYLE P1001AT 4-Channel 1000...
Install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Dec 04, 2012 | Pyle Plr34m In Dash Usb Sd Aux Am Fm Car...
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
Problems with FM with
That is very typical of tuners designed for the US market; US FM radio stations use only the odd numbers. In most cases, tuners made for the US cannot be adjusted for use in other countries. However, a few have an "area" control that can be switched; usually it's part of the setup menu. Check out your owner's manual, if it's available.
Jul 09, 2007 | Pyle PLCDUSMP74 CD Player
AM/FM receiver
Apr 16, 2007 | Harman Kardon AVR 225 Receiver
Televison & Video Logo
1,675 people viewed this question
Top Pyle Televison & Video Experts
Tom Chichester
Are you a Pyle Televison and Video Expert? Answer questions, earn points and help others
