Question about Cell Phones
How to set/fix the volume all incoming
How to set/fix the volume all incoming and outgoing calls
Ideally the volume has to be adjusted for each call individually. How can we avoid this
and how to bring the day of the week in the date and time setting of today screen
Version 6.1 windows mobile?
Thank you
Jayant
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
How do i increase the incoming and outgoing call volume
(For Kyocera Oystr)
Menu / Settings / Sounds / (choose topic) / (adjust up or down with button on side of phone) / save.
Ringtone volume, earpiece volume, key volume, speakerphone volume, etc.,
can ALL be found and set in the settings/sounds menu, and adjusted to your liking.
Nov 10, 2011 | Lands Phones
Can`t hear incoming or outgoing calls !!
HERE'S WHAT YOU'VE GOT TO DO:
1. Go to "Settings"
2. Click "Profiles"
3. Click "Standard"
Or,
1. Go to "Settings"
2. Click "Profiles"
3. Click "Standard"
4. Click "Settings"
5. Click "Adjust Volume"
Jul 23, 2011 | HTC HD mini Smartphone
When testing the outgoing message the volume seems
http://www2.bt.com/static/i/media/pdf/response_75_userguide.pdf
If you click on the above , go to p.11,12 on setting the volume .
I agree with everything you say the only thing I can add is you may not be setting the volume correctly see note on p12.
Hope i`ve helped.
Dec 10, 2009 | British Telecom Response 75 Digital...
Nokia n73
Please make sure your outgoing and incoming calls are not barred.
go to settings
go to call settings
go to call barring
and check the status of your outgoing and incoming calls.
There is also a line 1 and line 2 facility. Make sure you are using Line 1
Hope the above is helpful.
Thanks,
Kanu
Aug 04, 2009 | Nokia N73 Cellular Phone
I have some doubts on alfatel mobile functions
increase the volume while you are talking on phone call. You can increase the volume by press silver FM button. To reduce the volume use silver MP3 button.
May 11, 2009 | Handmark Software MobileLists (950142) for...
Kenwood KDC-BT838U -- Low audio on incoming phone calls only.
Patrick -
I have the reverse problem.  Callers can hardly hear me. I saw a setting in the headunit that allows you to specify where the audio plays for incoming calls.  You can choose the Left Front Speaker, the Right Front Speaker or Both.  Check the manual and make sure its set to both.
Regards, Charlie
Feb 02, 2009 | Kenwood KDC-BT838U Car CD Player
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Dec 16, 2008 | Samsung SGH-D600 Cellular Phone
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
Cell Phones Logo
111 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
