Question about GE Washing Machines
Ge washer wbse3120b2ww does not fill water and go to the final sp
I have a ge model # wbse3120b2ww washing machine and the water does not fill into the washing machine on it's own like before. The washing machine goes through the wash cycle and drain out the water but does not also go through the final spin process. What is wrong with it or what do I need to replace?
Washing machine does not fill, soak, and final spin does not work.
  • GE Master
  • 3,051 Answers
HELLO THERE
well it is looking like you have a water controle solinoid valve that is malfunctioning and needs to be replaces i would contact your nearest dealer to see what the part is going to cost and have it replaced and if you have a warranty with the machine see if you can use it .
best of luckmike
Posted on Jul 31, 2009
Ge washer WBSE3120B2WW. Washer stops at random places in the cycle on all wash settings. Sometimes it'll start and immediately shut back off. Used to be unplugging it between washes helped.
Great diagnosis for "do it yourself", go to:
www.repairclinic.com
Add your machine model number and look for your specific issue. They have videos that are of great help.
Nov 01, 2016 | GE Washing Machines
GE washer model WJRE5550K2WW - will fill water and drain but does not agitate and spin.
It new to me I am working on a GE washer model wjre5550k2ww it fill but not washing I can put it into the spin and it release the water but do not spin
Jan 05, 2011 | Washing Machines
GE super capacity heavy duty washing not filling w/hot water
On an older model washer, you probably have a bad water valve. (hot water solenoid coil electrically " open ") Newer models, now there's a can of worms. Some models use thermistatically controled water valves to limit water temps, so you may not be able to get true hot water. Also, if you are checking the temp as the machine fills, some models will only fill with cold if the lid is open. (safety feature) The only way to see what is really going on is to fill the machine with cold and use a thermometer to check the water temp, then, pump that out and fill (with the lid closed) with hot and check to see if that temp is higher. As stated previously, water temp may not really be " HOT " but may be warmer than " COLD ". That may be as good as you will be able to do, as all manufacturers are trying to reduce energy consumption. Thank your government.
Jan 21, 2010 | Washing Machines
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer model WBSE3120B2WW has electronic control assembly replaced. Unit will not start, all lights on panel are green and blinking.
I have a very simular problem. It started by running a cycle without me even being in the room. The only way I could stop it from filling and running through a cycle was to unplug it. I left it unplugged for about week & 1/2 - 2 weeks and when I plugged it back in, it worked just fine. It has started running by itself again but now I push the start button and nothing happens. Any solutions?
Jul 11, 2008 | Washing Machines
Washing Machines Logo
390 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
