Question about Tricity Bendix TM220W Electric Dryer
Drum will not turn when you push start button - take top off machine press start and push the drum by hand and it goes
    President:
  • 1,185 Answers
Motor or Capacitor sick depending on the drive type
You need a Man who Can
Posted on Jul 31, 2009
Why doesn't drum turn when the start button is pushed?
try turning the drum by hand while on dry cycle> just tape shut or hold door switch in by hand then have someone turn the drum? see if it starts? if so ur motor windings may be bad ad not pushing enough power to run machine, also check the thermal fuse and other thermostats as u may have shorted them somehow? lastly check the belt and tensioner as the motor switch may have switched off if there was a problem with the belt
Jun 03, 2014 | Samsung Dryers
Dryer does not start
I need more info about the dryer. Does you dryer make any noise when the start button is pressed, if you can hear the motor turning then more than likely your belt is either after slipping off the drum or breaking. you should be able to access the belt either by the back of the macine or the top to see if the belt is broke or just after slipping. Another problem it could be is that the capacitor in your dryer could have blown. To test this you press start, open the door of the machine, spin the drum by hand and close the door before the drum comes to a stop, if the drum continues to rotate after you close the door then you know it is the capacitor that is blown, this needs to be replaced either by an electrician or a specialist as it is possibe to connect the capacitor wrong and the result would be the capacitor exploding damaging your hand. Always plug out the machine before opening the top or back of the machine.
Jan 02, 2014 | Whirlpool Dryers
Whirlpool AWE 2214 Washing Machine won't start
I need more info about the dryer. Does you dryer make any noise when the start button is pressed, if you can hear the motor turning then more than likely your belt is either after slipping off the drum or breaking. you should be able to access the belt either by the back of the macine or the top to see if the belt is broke or just after slipping. Another problem it could be is that the capacitor in your dryer could have blown. To test this you press start, open the door of the machine, spin the drum by hand and close the door before the drum comes to a stop, if the drum continues to rotate after you close the door then you know it is the capacitor that is blown, this needs to be replaced either by an electrician or a specialist as it is possibe to connect the capacitor wrong and the result would be the capacitor exploding damaging your hand. Always plug out the machine before opening the top or back of the machine....
Dec 30, 2013 | Whirlpool Washing Machines
Spin cycle suddenly stopped.
I need more info about the machine. Does it make any noise when the start button is pressed, if you can hear the motor turning then more than likely your belt is either after slipping off the drum or breaking. you should be able to access the belt either by the back of the macine or the top to see if the belt is broke or just after slipping. Another problem it could be is that the capacitor in your machine could have blown. To test this you press start, open the door of the machine, spin the drum by hand and close the door before the drum comes to a stop, if the drum continues to rotate after you close the door then you know it is the capacitor that is blown, this needs to be replaced either by an electrician or a specialist as it is possibe to connect the capacitor wrong and the result would be the capacitor exploding damaging your hand. Always plug out the machine before opening the top or back of the machine....
Dec 27, 2013 | Whirlpool Washing Machines
Machine won't start
Nov 24, 2013 | Whirlpool Duet GHW9150P Front Load Washer
When start button is pushed the motor will buzz but yhe drum wont turn
Turn power off ,Will the bowl(drum) turn freely by hand.
If not turn by hand the bearings are seized,
It will need a seal & bearing kit & maybe a shaft as well.
Jul 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
When you press the start button the dryer hums and doesnt turn
first thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
Apr 18, 2009 | Dryers
Tricity Bendix TM220W Electric Dryer Logo
167 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
