Canon mpc 200 error message ''wrong cartridge'', won't print
Ink cartridges full, won't print, warning light flashing and error message ''wrong cartridge''. How do I solve?
  • deborah_gold Jul 31, 2009
    only ever used canon cartridges. Had ink tank full message several weeks ago but solved that. Could this be a follow on problem?
  • 313 Answers
If you have the old cartridge still check the connection to see if it is the same as you had and check to see if you have an original or compatible cartridge as some wont be recognised.if there is an electrical connection board in it see if you can change it onto the new one
Posted on Jul 31, 2009
We have a Canon Pixma MP280 printer and are getting an error message 6. How do we correct this.Please advise. Thanks!
r u sure that is e6?
There are bunch of error code for canon.
Pls check below and re-list your exact error code and can help you.
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 ? Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error ? USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error1
Apr 26, 2011 | Canon PIXMA MP180 All-In-One InkJet...
"Wrong Cartridge" Message is being displayed on the Canon MP 780
Remove the print head and cartridges.Unplug machine for 30 min.
Repower and reseat head and ink do a head alignment.
If this does not correct it may require service.
Ink Cartridges are the BCI6 and 3 series correct?
If using CLI8's and they are flashing red you have a bad cartridge or it is in the wrong location.If so Canon will replace the bad cartridge.
Jun 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E3-3 = Paper jam
E4 = No ink
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E29 = EEPROM error
E35 15 = USB Host VBUD overcurrent error - USB
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MPC400 - Error 335 - Ink ... Wrong Cartridge Error Message
How long was the cartridge in there? If the cartridge was in there for a long period of time the inc most likely leaked out and is now on the sensor bar and it cant see that you have replaced the cartridge. try taking some Q tips and some rubbing alcohol and cleaning the bottom of the cartridge, the cartridge holder, and the rail where the ink is released.
Mar 28, 2009 | Office Equipment & Supplies
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Installed new black and color cartridge.
Are they Canon ink cartridges?
Remove the cartridges, make sure that the tape is removed , and re-install them. Make sure they are seated correctly.
For future reference , these are the error codes for your printer.
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam error message
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Alarm light is flashing. cannot print
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
- unplug cable
- plug cable
Run the software.
oke
Aug 31, 2007 | Canon PIXMA MP160 All-In-One Printer
176 people viewed this question
k24674
jasbo
jasbo
