Ram compatibility i hav ASUS A8N-E motherboard will it support ddr-2 RAM....?
  • chandurepaka Jul 31, 2009
    but i have four slots ..which of them supports ddr..?
  • 4,924 Answers
Http://usa.asus.com/products.aspx?l1=3&l2=15&l3=171&model=455&modelmenu=1
I looked in more than one locations ...and all over I found something like this...even if it has great features for it's class ..it only has 2 slots of DDR mem and the max you can put probably are 1 G in one slot if it supports...but I sow that most of them are equipped with 512M Ram on 400 mhz (3200)..so ..I think you can upgrade the memory ..but never on DDr2 ..
Posted on Jul 31, 2009
  • Catalin Turcu
    Catalin Turcu Jul 31, 2009
    ok...this is another situation ....if you have 4 of them ...nore than sure 2 are on ddr and 2 on ddr2 ...see that they are on colors( different ) ...and ussually it is written beside which one is which ....also if you have the original manual ...take a look to see what supports and in what frequency's cause ...ussually elder ones ...like I have a 4 slots one ...supports only one kind of memory at the time ...and only on 533mhz ...and all they manufacture these days are on 800mhz ..but ya can still find on 533 second hand or in some stores that has in stock
    So...! if you have on DDr now...take a look on the slots color and put the ddr2 in the other slot...( different color) anyway ddr and ddr2 units dont fit but in the right slot...dont forget to remove the bios batery to restore the factory bios defaults ..cause your system will not recognize the new kind and won't boot ...if ya have any other questions ask...maybe I forget some issues...
  • Catalin Turcu
    I read what the other guy said ...and he also might be right ..even if there are 4 of them ..but they are the same color...they can be all on DDR (4of a kind) and it will support up to 1G on 400mhz in each one ...
    Take care and good Luck !
  • 1,511 Answers
No Sir, it will only support DDR / SD RAM. You can see the complete specs of your Board here.
If i was helpful, kindly do Rate! Regards.
  • Waqar Hassan
    Waqar Hassan Jul 31, 2009
    All of them Sir, the SD/ DDR slots are same.
    You can place the RAM (DDR or SD) on any of them.
My mboard have 4 slot of RAM DDR, but i can't put all my RAM on all (4) slot, only 3 slot my comp can read (my RAM is DDR 512 MB pc3200 x 4) soo.. i have 1 Free DDR 512 and 1 slot.. please..please guide...
Looks like you have the right kind...they have to match you know...you could try 2/1g sticks instead...
Your compatible memory is here: http://www.crucial.com/usa/en/compatible-upgrade-for/ASUS/p5gpl-x
Jul 22, 2017 | ASUS P5GPL-X SE Motherboard
Which kind of RAM my motherboard is compatible?
It supports maximum of 2 GB of DDR RAM
DDR here means DDR 1 and not DDR2 or DDR3
Rate it, if it helps.
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
I can't recognize what specific RAM this motherboard accepts..
Dear sir,
In reply to your post- Generally now a days we use DDR400 RAM(DDR 1) for this type of motherboard.So DDR 400 RAM is More compatible then other RAM,you can use this RAM for your motherboard to obtain good performance.
good luck
chandrashekhar
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Dec 16, 2008 | ASUS A8N-VM Motherboard
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
ASUS A8N-SLI memory issues
imondeau, do you still have you're manual for the ASUS A8N-SLI Premium? Please turn to page 2-12 & 2-13.
Need the manual? Click the link below & download it.
http://support.asus.com/download/download.aspx?modelname=A8N-SLI%20Premium&SLanguage=en-us
The QVL; Qualified Venders List, shows all the tested memory for this board. Edge memory is not supported. This is why the Edge memory only runs by it's self. Once you add the corsair memory they clash because they are not compatible working together in this Asus board. Both sets of memory could work in another board. (Maybe)! What is also needed is if the corsair & edge DIMMs are SS = Single sided or DS = Double sided. How many chips on the corsair? How many chips on the Edge?
They must have the same total chips each each DIMM.
Edge does not sell memory compatible for the
Asus A8N-SLI Premium.
See this for you're self. Click on this link:
http://www.edgetechcorp.com/memory/
Mike
Jun 17, 2008 | ASUS A8N-SLI Premium Motherboard
I have an ASUS P5S899-VM motherboard and wish to install 2 x 1gb Samsung ddr PC3200 184 pin ram. Is this ram compatible with the motherboard? Many thanks, Colin Sinclair.
First you have to know the mother board supports the ram with ddr 1 and ddr2 . Now the new technology motherboard are supports only ddr2 ram and the ddr1 ram are consider as the older version. But ASuS P5S899-VM is contains the new technolgy of ram slot please see the manua or the mother board box. there you can see which it supports.please check it
Apr 28, 2008 | Computers & Internet
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
Ddr and ddr2
You cannot use DDR2 since your mother will only support DDR1 which is DDR400 compatible only.
Please don't rate me Inappropriate if you don't like my solution or rate me SOLVED if you accept the reality. Thanks
Nov 22, 2007 | ASUS A8N-SLI Deluxe Motherboard
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
