Question about Bosch Axxis WFL 2060 Front Load Washer
Drum not turning - Bosch Axxis WFL 2060 Front Load Washer
  • 82 Answers
Brushes have gone can be trickey to do take the plug out then take the back off remove the belt and take off the moter once off look at the back side and there will be a spring with a wire on a tab take the wire off slide the tabe back and lift and the brush will come out try espares for repacements spin the moter when new brushes r fitted if it sounds noisy then u have put the brushes in the wrong way round
Posted on Jul 31, 2009
    Brigadier General:
  • 3,513 Answers
Would request you to please do the following steps to get the drum spinning again.
Switch off power, disconnect hoses, open pump housing to completely empty machine of water.
Turn the machine upside down onto a soft surface - e.g. a blanket on the floor, and carefully cut the cable tie holding the motor cable and splashguard to the motor body; disconnect the motor connector and earth spade to facilitate easy access to the more visible brush block. The brush spades disconnect easily, then the brushes are extracted by sliding each spade terminal inwards toward the motor spindle until the connector end is released from the block, then pull the other way to release the inward end - withdraw the spring/brush assemblies gently from the carriers. The brushes are clearly on either side of the motor spindle but see how they do not fit on a diameter of the motor axle but are inserted tangentially - the curve on the brush is polarised to take this into account - you want to have the wider carbon contact surface of the two fitting options possible. Reassembly is simple but make sure you do not reconnect the mains supply if any water has been spilled into the top of the machine... leave it for a day or so to dry out You can test the motor using the spin cycle before re-installing the machine properly.
Thank You for using Fixya.com
Konica c2253
One of the drums is unable to turn, pull each one out. check them, physical turn drum make sure you turn them correctly, and use the edge of the drum not just put fingers on any part of the drum, might. one at atime hav to get a color drum and black drum they are different and replace the black if not that the replace the color one
Jun 23, 2014 | Konica Minolta Bizhub C360
Minolta cs pro ep 1085 errore code c0010
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it.
Nov 23, 2013 | Minolta Office Equipment & Supplies
I have a minalta cs pro ep 1085..when I tried to take copy the paper jumed and errore code apeared (c0010) ,, any help will be greatfull
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it. Hope this works for you
Hope this works for youH
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer does not start. Drum does not turn by hand. Only makes a sound when switch is turned on.
If it is a sound like a loud hum, the motor is either fried or something is jammed preventing the drum from turning. It could be something like a sock. You just have to open things up and look around carefully, especially around the outside of the drum.
If the noise is a more normal one but the drum is not turning, check that the belt is around the drum and not broken. Some drums are just fairly hard to turn by hand, partcularly if the belt is still around the drum.
Sep 19, 2009 | Dryers
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum will not turn.
Sounds like you've got something stuck in between the drum and tub the best way to check is through the heater at the rear of the machine. Could also be the motor or drum bearings have seized if its the drum bearings there's usually brown oil coming from the back of the drum. Take the belt off to see if either the drum or motor can be turned manualy. hope this helps.
Dec 12, 2008 | Zanussi F1045W Front Load Washer
Dryer Motor won't always start Model FSE747GES
Too much drag on the Drum. Try lubricating the rollers that the drum turns on. Check the belt tensioner pully...lubricate that as necessary. If Drum still turns very hard after this then take belt off of motor and try turning drum. If drum turns easily then replace motor.
Nov 24, 2008 | Frigidaire FDE336RE Dryer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
Bosch Axxis WFL 2060 Front Load Washer Logo
320 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
