Question about Proform CrossTrainer Treadmill
PROFORM RUNS BUT WHEN I STEP ON IT EITHER SLOWS DOWN OR STOPS MOVING AT ALL
    President:
  • 1,185 Answers
Belt needs tensioning up on its adjusters or the motor drive gear has come loose and needs tightening back up.
Posted on Jul 31, 2009
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
Proform C950 intermittently stops working shortly after start
please see the video attached. lube the rollers bearing front+ back
2) test the input terminal voltage motor, if there ARE the motor is faulty. see my personal TIPS for motor help 3) test the output voltage board, if there ARE NOT voltage for input voltage MOTOR, the board is faulty.
God bless you
Nov 27, 2013 | Proform C950 Treadmill Walking Belt
Can I dismantle proform 360p to move it
When plugging my treadmill in it was going at max speed without the key even in. Now it has slowed to a complete stop and I can not get it to move. The incline works, but not the speed.
Jul 08, 2011 | Proform Exercise & Fitness
I have a proform 740CS, it sometimes slows way down, if I step off it will sometimes speed up much faster than what it's set at, but then slows down again when I step back on. Other times, it remains...
Please LUBE very well the Walking Belt.
2) Inspect the drive belt motor, if is loose, Retight.
3) See if there loose wires for MOTOR.and retight.
4) The walking belt LIFT wiht your finger must be 2-3"
otherwise Readjust with the allen screw rear.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How To Lubricate Treadmill
Nov 22, 2017 | Proform 7.0 Crosstrainer Treadmill
Treadmill slows suddenly and when i step off it starts again. only happens to me.
hi it sounds like the belt is too loose, i had the same problem when the wife uses the treadmill works perfect, untill i step on it really slows down and once i step off it runs fine. so i tightened the belt just a fraction and now works fine. check your instruction manuel it will explain how to do this. normally its two screws at the backend of the roller. hope i have helped.
Nov 15, 2010 | Proform XP Weight Loss 620 Treadmill
Got a 390pi proform and when I step on the
Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lifting one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck.
Jun 01, 2010 | Proform Sport 1000 Folding Treadmill...
I have a model 297980 J8 proform treadmill. when I first start it up without the safety key in it, the treadmill runs at full speed for about 2 minuets. After that it slows down and stops. The speed is set...
You have to put the safety key in if you want to select speed/incline or predefined programs.
It starts and runs at full speed on that occasion because it's part of the maintenance process, that lubricates the inner rollers so that it will continue to work perfectly for as long as possible.
May 01, 2010 | Proform Exercise & Fitness
Treadmill stops when I step on it?
your running belt might b on 2 tight or u dont have enough power going 2 the motor make shure u have a designated power line 2 your machine
Dec 20, 2009 | Proform 730 Folding Treadmill Model...
Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Jul 30, 2009 | Proform CrossTrainer Treadmill
Proform CrossTrainer Treadmill Logo
509 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
