Question about LG Over-the-Range Microwave
Exhaust fan does not work. Under light does not turn on
  • LG Master
  • 9,047 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 01, 2009
Samsung microwave oven Model # SMH9151S. Turntable not turning fan inside (not the exhaust fan) is not working either.
It may be a failed relay on the control board, which I repair affordably.
See my profile picture if you need more help.
Jun 22, 2015 | Samsung Microwave Ovens
LIGHT, turntable, and fan don't come on
follow this test and fix it. God bless you
  1. Exhaust fan motor If your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. Thermostat Another part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control board If your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Dec 09, 2013 | GE CVM2072SMSS Microwave Oven
Controls, heating and turntable function normally, but there is an intermittent failure (approx 80 of the time) where the interior light and blower do not function when the microwave is operating .
follow this test and fix it; God bless you
1)
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
2)
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 31, 2013 | Jenn-Air JMV8100A 1000 Watts Microwave...
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
Oct 24, 2013 | Frigidaire Microwave Ovens
My 900 em do oven keeps over heating and switching off
follow thes steps and fix it.God bless you
Exhaust Fan Motor
If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it doesn't, replace it.
Thermostat
If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board
If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.1_24_2013_5_50_54_pm.gif1_24_2013_5_53_00_pm.jpg
Jan 24, 2013 | Microwave Ovens
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Exhaust Fan Turns on by itself and will not shut off
Your hood TCO may be shorted. It should read normally open.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.Or if you've recently had a blown cooktop light, it may have damaged your fan control on the circuit board.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
May 13, 2010 | GE JVM1750SMSS Microwave Oven
GE Profile Microwave - JVM2070SK02 - when turning on the underhood light there was a bright flash/pop - both underhood and interior lights are out - carosel doesn't turn - fan sounds labored - control...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Sep 13, 2009 | GE Microwave Ovens
GE XL1800 Microwave Problem
First of all, unplug the oven when changing the bulbs, and use good quality bulbs form a home center, as opposed to dollar store or grocery store subs.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar microwave exhaust fan will not turn off
We had this happen to us tonight. We unplugged the microwave oven for 15 seconds and then plugged it in, but it the fan was still running. We then unplugged it for 30 minutes and the fan worked properly when we plugged it in again.
Jan 09, 2008 | Microwave Ovens
LG Over-the-Range Microwave Logo
393 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
