When I switch on my PC there no display - Computers & Internet
  • 89 Answers
Firstly check for the connection between cpu and monitor if it is correct then remove your ram and place it again
Posted on Jul 31, 2009
How can a get the screen on hp slate2 turn sideways
The power switch of the Slate 2 is a 2-way switch.
The user can slide the switch towards the lock symbol to lock display from auto rotating. So move the switch away from the lock symbol.
HP Slate 2 Tablet PC Disable Display Auto Rotate
Sep 24, 2014 | Computers & Internet
How do I get out of no input signal
Hello
The video signal is not getting into your display.
Check the connections on both sides of your cable (display side and display card side). If that didn't help, switch off your PC, make sure youre display card is in its correct place (try taking it out and putting it back again). Switch on your PC and check again. If the problem continues, try replacing your display card.
Aug 11, 2014 | Sony VAIO Computers & Internet
I have problem with my acer aspire one loptop, has power but no display,,, what i'm going to do?
First, reboot.
Second, try switching the display mode using the Fn key and the corresponding display function key. It may have just been accidentally switched to the external VGA port, and hitting it again will switch it back.
Mar 17, 2010 | Acer Computers & Internet
HDMI from laptop to Mitsubishi TV worked once and stopped
Sounds like you set HDMI as your primary display device. Try reconnecting to HDMI and use the Mitsubish to make your changes while the laptop is connected. You will need to click the LCD Icon when it shows you the 2 monitors then turn off the HDMI device in that menu. Then select the VGA screen as your primary display device. This can be done with either the displays manager or the optional software supplied with your laptops display. remember to always switch back to your primary video device (LCD) before switching off your PC or laptop since the display resolutions on Hi-Def are completely different than a VGA device as well as the display frequency.
Windows, as well as Bios will prevent your PC from displaying resolutions and frequencies that may damage your Video card.
Mar 14, 2010 | HP Pavilion dv7-1130us laptop
I am not getting the screen to display stuff from my computer . I don't know if I hooked it up correctly, I need a walk through.
Double check the connection. Once you are sure that the cable is properly connected and the cable itself is not damaged, you may need to switch the output on your portable PC, assuming that is what you are using, based on the icon. If it is a notebook PC, they often have a switching hotkey command that is used to switch output of video between internal display and external displays. Try that... Also, make sure that the external display is capable of displaying the resolution your PC is sending, as this can also cause it not to work.
Sep 26, 2009 | Acer Aspire One PC Notebook
2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
May 16, 2009 | Belkin F1DK102P 2-port KVM Switch
Message showing - player problem connect pc and fformat player
i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
Why is my Monitor blank when i switch on the pc?
Normally, blinking indicator lights and no display on the monitor indicating a wrong resolution or refresh rate frequency, that the monitor can not display it.
To fix, enter safe mode, and configure the display to the lowest resolution. After restart, you should be able to have the display.
Dec 31, 2008 | Intel D945GCCR Motherboard
Philips firmware upgradation
on switching on mesage displays connect it to pc and repair using philips device manager , what to do now ?
Jul 06, 2008 | Philips GoGear SA3125/37 MP3 Player
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
