SOURCE: internet problem
It could be several problems:
1. Your wireless router misconfiguration.
2. Your wireless router is bad
3. Your wireless card misconfiguration on your laptop
4. Your wireless card is bad.
If you never had problems with your wireless connection before and you haven't change configuration on your router or your laptop. I have seen and repaired this problem by replaceing wireless router.
Good luck!!!
SOURCE: acer aspire 5315 crystal eye webcam
Check first your webcam if its is installed properly... the message poop bcoz the system cannot find connected webcam its not acttualy about your connection to the internet..
SOURCE: Can,t connect to internet
Here is a link to Palm support services. I recently had a problem with
my TX and I did the free chat service they offer. The technician I had
completely solved my problem. You can do a phone support if you want
but that will cost you around $15. The chat and forums are free. The
chat feature is towards the bottom of the page. Hopefully this will
help. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/supportservices/page_en.html
SOURCE: my touch shows that I have a wifi connection, but i cant use it.
All you have to do to the ipod is go to settings, wifi and make sure its turned on in the same place you should see a list of wifi networks you can connect to just tap the one you want and the ipod will do its thing your done, but if you done all that and you ipod doesnt go online says connected but wont access the net, my guess is the wifi router you mite have some prob with that, make sure the internet ethernet cable is pluged into the modem plug not the numbered slots after this you should be good to go unless your wifi modem is new if so some req you to plug it to your computer via ethernet cable to program it first! Hope this helps
SOURCE: my PSP internet connection not supported to my access point.
The SSID is the NAME of your Routers connection. So you need to know your WiFi connections Name, That's the "Access point" Security, Is IF you assigned a WEP/WAP KEY, when the router was first setup. If NO Key is set, that is what it means "Unsecured",
You need to get a Netgear router manual, for your exact model, it shows all in pictures how to do it.
