Question about UTStarcom Blitz Cell Phone
Blitz slider phone in 2 pieces needs put back together
My starcom blitz slider cell phone is in 2 pieces - the keyboard and the screen. Any chance I can ''reattach'' them? Thanks!
Fix screen
screen still black / white it's not a screen problam .
it's belt problam
change your belt of cell who connect your slider to your keypad
that belt.
Jun 23, 2013 | UTStarcom Blitz Cell Phone
Samsung Slyde has a spring out of place
You cant without destroying the phone. A problem like that needs to be repaired by the manufacturer (samsung), they will have to reflash the phone when they are done with the repair. Slider phones are never meant to come apart after being put together once.
Apr 14, 2010 | Samsung Rant Cell Phone
Instructions to replace the samsung sgh-a877 lcd screen?
needs major work. Do it at your own risk. Did everything right but messed up and broke the tab on the touchscreen cable connector on my daughter's phone. Feel crappy. Will post with pictures later on.
1. remove battery/ Sim 2. remove all screws from the back on the black plastic cover. (6 of them) Leave the ones below the battery. 3. Use the pry tool to remove the back case. 4. remove the motherboard, three connectors, one on bottom left, antenna and top right below the board. board comes off. You also have to remove the power connector (transparent plastic) to what appears to be some hf component (cylinder). there are two wires (red, black), red goes to side marked +. remove with pry tool. 5. Remove all small screws you can see. 6. Remove the shiny plate, keyboard button layer. 6a. Remove the lcd connector screw and the connector. 7. Remove screws from the bottom of the lcd portion of the slider. You can access all screws from the back side. Use the slider to get the back of the phone. There are 5 screws. 8. Use the pry tool to take out the back slider. Be careful with the lcd connector. 9. pull up the black tab on the digitizer connection from the screen 10. remove the lcd 11. use a hair dryer to loosen the glue around the broken digitizer. 12. put the new one in 13. Put all the screws back.
Apr 10, 2010 | Samsung SGH-A877 Impression Cell Phone
MY PHONE IS LoCKED AND I CANT REMEMBER THE UNLOCK CODE
the only way to change that password is to send it into verizon.
Feb 25, 2010 | UTStarcom Blitz Cell Phone
Lens scratched on lg shine , how do i replace
Visit this web page for a picture guide to repair your screen. http://tiny.cc/YaTay
Directions to repair the screen on an LG Shine:
Step 1. Take off back cover and remove battery and SIM card.
Step 2. Remove the six screws holding on the back cover.
Step 3. Get a thin piece of metal and pry off back piece of the main phone unit.
Step 4. Once you get the back piece off you can see a green unit at the top of phone. This is the camera, all you do is pull on it and it should un-clip.
Step 5. Once the camera is removed you can see 4 more screws, unscrew these.
Step 6. Now that the screws are out you can pull off the main board. The first thing you need to do is un-clip the black ribbon that is at the top. Then you have to un-clip the clip on all four corners, after you do this the main board will come out.
Step 7. Now That you have that off there are 2 screws on the back that you must unscrew.
Step 8. With the screws gone you can now pull the slider away from the piece that has the number pad on it.
Step 9. On the back of the slider there are 6 screw you must unscrew. The Two screws at the top have small black circles glued on-top of them. Just wedge something under the black peices and they will come off.
Step 10. Now that the screws are out you can pry off the plastic LCD screen cover from the metal slider piece.
Step 11. After the LCD screen cover is gone you must unscrew 2 screws to the left and right of the joystick. After you remove the screws the joystick cover comes off.
Step 12. Now that you have the cover off you need to turn the plate where the joystick is on over and pull out of the LCD screen clip.
Step 13. After you do this you can now put in the replacement and put the phone back together.
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | LG Shine KE970 Cellular Phone
Blitz Phone only works when charged
the phones just a piece of **** mines doing the same thing and its not the battery the phone needs to be recalled
Jan 28, 2010 | UTStarcom Blitz Cell Phone
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
No source of Power with BLitz
you need to service the pannel to make it work fine or change the charging port it may be faulty or put in small led to sold it back it might be broken.
Jul 17, 2009 | UTStarcom Blitz Cell Phone
How to fix a pantech matrix
 I had the same problem.   If you take the battery out there are four small screws holding the back of the phone together.  Once you take these screws out there are two more screws under the camera/speaker panel.  Before you can take these two screws out you'll need to pry of the speaker/camera panel.  The seam where you'll pry is on the same plane as the battery cover - phone seam.  Once you pry it off and take the screws out you'll be able to open phone.   From there you will find more small screws (4) that hold the vertical slider action together.  Once you take these screws out you will be to take out four more screws (2 on top side of phone on either side of micro sd card slot and 2 on the bottom side of phone.   Once you get these 4 screws out you'll have to pry that plastic piece off.  With the plastic piece off you will have access to four screws that hold the texting slider together.   Line up the texting slider screws with the holes in the metal sled on back of phone screen section and tighten.   Now put the phone back together and it should work.   GOOD LUCK! If my instructions are too confusing just use common sense and you should be okay.
May 15, 2009 | Pantech Matrix Cell Phone
UTStarcom Blitz Cell Phone Logo
196 people viewed this question
Top UTStarcom Cell Phones Experts
iphone service
buzzcola
Level 1 Expert
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
