HP Network Adapter
Problem for HP (C7200-69016) (C720069016) Network Adapter
Send and receive fax
By prissybaby on Nov 24, 2007
i bought a new hp C7200 printer andi have been able to fix everything except the fax.can you please help me with this
Same Problem
Dec 19, 2008
-   I also have fax problem with HP C7200 (error code 388). The HP help site is useless for my problem. I have Vonage (VoIP) and cable service. It was working fine until my original cable service (Wavecable) was replaced by another company (Charter). My feeling is the cable company's equipments have a lot to do with it. Charter is one of the worst cable service I have experienced which adds to the problem. -   Guest
Dec 11, 2008
-   CAN'T USE THE C7200 TO SEND FAXES WHILE ON THE INTERNET, (DSL BROADBAND), ISN'T THERE A WAY TO WORK "OFF-LINE", WITHOUT SHUTTING DOWN THE INTERNET. ALSO - FILTERS HAVE BEEN INSTALLED THAT CAME FROM THE DSL INTERNET SERVICE PROVIDER.
-   Guest
Solution #1
posted on Nov 24, 2007
Not Rated)
vikasjain89
Rank: Apprentice
Rating: 0%, 0 votes
Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections
  4. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine.
Faxes cannot be sent but can be received Follow the steps below to correct the problem.
  1. Verify that you are dialing the number correctly. You must dial all of the numbers required to make a phone call from the same line. This includes numbers that must be dialed to access an outside line or to access long distance services.
  2. If you have been using a speed dial or are faxing from the computer, print the page to be faxed and manually dial the number from the front panel of the fax. If the fax can be sent when dialed from the front panel, recreate the speed dial setting and insert some pauses.
  3. If you are trying to fax from the computer with a model that supports PC faxing and the fax does not try to dial when you send a fax job, test the communications to the all-in-one by clicking Status in the Director, or by trying to print to the all-in-one.
    • If this is reported as disconnected or printing fails, verify that the communications cable from the computer to the all-in-one is connected correctly and restart the computer.
    • If communications still cannot be established, troubleshoot the communications
  4. Faxes fail intermittently or with only one fax number
    • If static is present on the phone line, fax communication may fail. Have the phone line checked and serviced by the telephone company (or have the other party check their line). Phone line quality is the most common reason for intermittent fax failures. Some older locations and buildings have inadequate phone system wiring.
    • If you are trying to send a color fax and it fails, try sending the same machine a black and white fax. Normally the fax will detect that the other fax is not color capable and will offer you the option to send the fax as black and white but this might not always be the case. Do not send color faxes unless you know the other fax machine is capable of receiving color faxes.
    • Check the phone cable from the wall jack to the fax. It should not be coiled or longer than necessary. Coiling the cable can cause cross talk or echo on the line. Signal strength and quality can be lost with long cables.
    • Make sure the phone cable routing (and any cables not plugged into the same jack but sharing the same line) is not near any electrical appliances (electric motors, fans, kitchen appliances, or televisions). Many of these devices do not have sufficient electrical shielding and can induce electro-magnetic force (EMF) onto the phone line. Computers are usually shielded sufficiently and do not cause this problem.
    • Do not use a call-waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
    • You can block certain faxes on some models. Verify that the telephone number of the sending fax is not blocked in the faxing software. This is usually located in the Fax History.
Was this helpful?
Yes
No
Popular Solutions for HP Network Adapter
Questions and Unsolved Problems for HP Network Adapter
Do you recommend HP (C7200-69016) (C720069016) Network Adapter?
Answer
Answer
Photo smart D7560 printer. Message says photo tray problem. re insert or lower photo tray. I think I... (More)
Answer
When I try to print photos from a memory stick it fails to print and tells me to load paper glossy... (More)
Answer
my hp c7200 won't print AGAIN. I'm starting to think this printer is not worth the $$ I paid for it.... (More)
Answer
photo tray problem !! lift output tray up , verify the photo tray is pushed un untill it stops lower... (More)
Answer
I have a mac computer now, it worked before on my windows computer. The photo tray will not work... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Network Adapter:
Top Network Adapter Experts
Rank: Guru Guru
Solutions: 3661
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Network Adapter Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
