Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Brought door with lock locks when u push lock
But have to use key to open as using pin only locks door as well is new and trying to set up thank you
    President:
  • 704 Answers
You might not be pushing the correct sequence of buttons to unlock the door. You should only have to enter in your code to unlock the door, unless there was a problem when the lock was programmed.
Here's a copy of the user manual so you can verify the codes were entered properly and that the lock is set up correctly.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
Posted on Aug 19, 2009
My key broke inside the door lock of the passanger door of my lincoln ls 2000.how can I replace door lock?
You might be able to retrieve broken part of key. Take a bobby pin or paper clip and straighten, or if you have a scribe.. I will include picture of a scribe. Push the cover of lock cylinder in with scribe,bobby pin or paper clip and make sure you can see the remaining part of your key...if the key is not twisted i would put asmall drop of super glue on the part of key that came out and while holding cover of lock open insert and hold against broken part of key for abt 30 seconds and key should remove with brokenpart attached...if key is twisted, use a small flathead screwdriver to glue to piece of broken key.
Replacing a key is much cheaper and far less time consuming than replacing lock assembly. If you can not get broken part of key out. I will tell you how to replace lock assembly...good luckkey-broke-inside-door-lock-passanger-lssthgpi25gedqz0c32oowfn-4-3.jpg
Sep 18, 2015 | Lincoln Cars & Trucks
2003 Legacy sedan - can't open trunk from outside
Open the door, remove the trim and service the door lock mechanism.
Jun 19, 2017 | Cars & Trucks
How do I slim jim into my 2006 chevy colorado with the keys locked inside?
it depends if your door has the antitheft plate,most cars have them now,its just a small metal plate inside the door to stop a slim Jim,if you door has a lock pin you can hook with banding that's the way to get in,but you will need a wedge to open the top of the door just a few mm then take the banding fold it in half and push it in the gap then slide one half forward to open the banding hook the lock pin then close the banding and pop the lock ok.
Jan 30, 2012 | 2006 Chevrolet Colorado Regular
Driver side door is frozen open with lock closed. Try to close door and it bounces back. Unlocking with key or with auto-lock does nothing. Key turns, lock button goes up and down, but mechanism does not...
Give the locking "jaws" a good dose of WD-40 and start with a pair of pliers ans working the door handle get the "jaws" moving and work it a lot while keep dousing it with the lubricant. Worst case scenario would be that the spring that opens the jaws is broken and will need replaced. Please rate this answer, thanks.
Feb 06, 2011 | Ford Taurus Cars & Trucks
I have a '04 rio and the driver side door is stuck shut, when the manual lock pin is pulled up, it snaps back down like its on a rubber band.
JEB, Homestead Florida
Total credit to rfbqwerty
Have 2003 Kia Rio 1.6, door shut, locking pin springs back down, I followed rfbqwerty istructions to the Penny and it worked in about 20 minutes I was able to open the door. The restst is a POC, thanks a million!!!
Option found in Google 6/16/2012
rfbqwerty
03-28-2006, 06:22 AM
Easy method to open a stuck Kia Rio door. Full credit to 'fastkia' for explaining how to open a stuck lock but after opening my lock by his method I found an easier way to do the job. You need a piece of straight wire (clothes hanger is good) and make a 3/4 inch square bend on one end. Wind down the window & push a tapered (plastic) wedge between the glass and the inside rubber to get a gap to work through. Poke the wire down beside the glass and pull up on the lever that is operated by the outside door handle. This is not the wire from the door handle but is the lever the wire connects to in the lock. While the lever is held up by your hook you can now pull up the locking button. Remove the wire from the door and everything works and it can be opened and closed as often as you like but don't press the button or use the key lock or it will be stuck again. The lever is normally held up by a small spring that has a sharp bend at one end and the spring will ALWAYS break at this bend. I used the same spring with a 'new' loop made from a section of paper clip to replace the old loop. Better than the original. No cost and it took less than 30 minutes
Mar 09, 2010 | 2002 Kia Rio
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
Door lock 2004 jetta wagen
If remote locks and unlocks driver door but does not unlock passenger doors,then follow the advice above:
Get in the car using the key to unlock the doors. From the passenger side lock and unlock your doors using the button on the passenger door. Get out and the remote should now unlock all the doors with 2 presses.
Worked perfectly for me after several other suggestions (and dealer) failed.
Nov 07, 2008 | 2004 Volkswagen Jetta
2004 Civic Drivers door lock
The driver's side door lock button is designed not to lock from the inside unless the handle is pulled, or the power switch is used. This serves as a reminder to not lock your keys inside.
If you are inside, and push down on the button (not the switch) hard enough to lock it, you've probably damaged it.
Jun 09, 2008 | 2004 Honda Civic
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
167 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
