Question about Baumatic 23 in. B10 Electric Cooktop
Cracked glass top on frameless Baumatic cooktop
The glass edge on our frameless cooktop is cracked and is not covered by insurance. It still works perfectly. Is it possible to just replace the glass top instead of buying a complete new unit?
    President:
  • 1,185 Answers
Click on the link below , it is the UK page but has the information on that you require
Email them and ask for the USA oulet
http://www.4baumatic.co.uk/cgi-bin/search.pl?query=Baumatic%20B10&brand=Baumatic&model=B10&path=110822&model_pre=B10&model_ref=89866&brand_ref=2
Posted on Jul 31, 2009
Smeg hob cracked on the bottom left side. It still works perfectly, however I'm wondering if I can just replace the glass, or if I need to replace the whole thing? Im looking for the cheapest option
The cheapest option is to araldite the crack (assuming it's not over the hot part!) and live with it. I doubt it is economically viable to replace the glass, it will be quicker and easier to replace the hob if you can get one with the same hole size. The only way it would be cheaper is if you find a second hand one on an auction site. You might be covered on your buildings insurance but a claim won't be cost free.
May 12, 2014 | Smeg 23 in. SA435X Electric Cooktop
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
Cracked glass top stove. is it covered under a waranty? it is maybe 4 years old. brought at sears its a whirlpool stove.
whirlpool offers a five year warranty on glass cooktops for thermal damage only not for customer mishaps so call a certified repair place and they can get you a new cooktop if you tell them that it is thermal cracking
Sep 12, 2009 | Cooktops
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Feb 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
My glass top cover shattered. Where can I get a replacement?
Any appliance parts dealer can order it for you but it may not be worth it. This part can cost over $400. NEVER operate a cracked top as it can explode violently.
Jul 10, 2008 | GE 36 in. Profile JGP963 Stainless Steel...
Broken glass cook top
The top can not be repaired. The glass must be replaced . DO NOT USE IT CRACKED!!!!!!!!!!!! This is very dangerous as it can explode from the temperature. Also this is a severe electrical danger as glass top units have exposed elements underneath. Any liquid at all can short it out and cause a fire. I don't know if it is worth repairing. I don't have the exact price for your cooktop but last one I priced was between $350 - $500.
Jun 26, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 | Cooktops
Baumatic 23 in. B10 Electric Cooktop Logo
499 people viewed this question
Top Baumatic Cooktops Experts
Rod Doney
Rod Doney
The Vanguardian
The Vanguardian
Pete
Pete
Level 1 Expert
Are you a Baumatic Cooktop Expert? Answer questions, earn points and help others
