Question about Cell Phones
Sci Phone. Same clicking problem.
New Sci Phone, have it only a few days. Makes the same clicking noise when in idle mode, just like a camera click. Actually somebody asked me testerday if my camera was taking pictures in my pocket! Any info very much appreciated. Thanks.
Whats Happening to my car? It makes a weird click noise then idles rough and dies.
Check your maf/map sensor. Could also be your starter on its way out
Apr 01, 2015 | 1992 Ford Crown Victoria
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
Very Slow....Light Black Screen when opeing
If it has not corrected itself by turning the phone off and taking the battery out for a couple of minutes then turning it back on you should try a factory data reset. In Idle mode, open the application list and select
Settings - Privacy - Factory data reset - Reset phone
-Erase everything.
May 23, 2012 | Samsung S6102 Galaxy Y Duos - Black...
Makes a clicking noise when you use the telephone
Most likely there is a jam inside the lens assembly, and the gears are trying to engage. There are a few things you can try, and about 1/2 the time, they fix it. Here is the blog that details what to do and try, and it's worth trying.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Short of that working, it's usually not cost effective to have it repaired, unless you get a really good deal from a buddy who knows how. Get an estimate before considering service, since, as you've probably guessed, it's often better/cheaper to just get another new one. Good luck, and hope this helps.
Jun 19, 2010 | Nikon Coolpix 4300 Digital Camera
Lens making strange clicking noise when turned on or zoomed in.
If the noise wasn't there for 3 days and is there now, it can only get worse. I would return it for a replacement.
Apr 27, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
My camera wont turn onit makes a clicking noise.
problem of the lens unit not getting opend well,so get it serviced/replace it
Feb 28, 2010 | Samsung Digimax S730 Digital Camera
Nikkor 70-300 f/ 4.5-5.6 AF noise followed by "click"
Well most AF mode do make a noise of some sort because its trying to adjust for a clear shot. I've played with several cameras and their features and notice this is a common thing, its usually the camera. But if your really worried about it and it does bother you, just take it in for a service. Maybe because of you dropping it several times, the noise is more louder now.
Sep 08, 2009 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Camera won't turn on. It just makes clicking noise.
After i replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Jul 18, 2009 | Fuji FinePix A850 Digital Camera
Turn off Samsung U900 Soul camera shutter sounds
press the red button on the side to open camera mode> click the little menu button (this should be the right hand button when you use your phone normaly)> scroll across to the very last option (this should be settings)> click okay> scroll down till you find an option saying shutter> click okay> chose none and click okay to exit it.
if this doesn't work put your phone in silent/ meeting mode
Mar 25, 2009 | Samsung U900 Soul Cellular Phone
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
