Question about Kenmore 75085 Air Conditioner
Loud rattleing sound
I recently put in a new air conditioner. It works good to cool down my room but there is a very loud rattling sound coming from inside. I reinstalled the unit to make sure it was installed correctly but the noise has gotten louder and louder over the past week.
  • rachellej64 Jul 31, 2009
    I should say it is brand new, but it is 5 years old. It was never used and still in the factory sealed box when I got it.
  • 700 Answers
If this AC is a thru walled, since it is new it is better to inquire to the people where you buy this unit, for this type of problem. They must have some authorized repair man/shop or, use its product warranty.
The problem could be also uneven placement of its base. This could maybe hitting the fan guard, some loose connection or some foreign object left that's hitting something inside.
Posted on Jul 31, 2009
  • fougzki Jul 31, 2009
    Check its base maybe some gap that gives it some rattle. A small piece
    of spacer could do the trick or wood to find the fault temporarily. Or
    maybe some lizard or mouse frequently visit it then before you decided
    to use it.
    Checking the inside is one sure way of doing it, if you have knowledge
    you could check it by yourself or have it check by an authorized AC
    repairer.
I have a DeLonghi PAC-CT90 air conditioner, it works great and cools very well, however it's recently started this rattle or clicking sound that's constant and loud. It still cools wonderful, and the...
I couldn't find much online, but clicking sounds sound like relay issue
Here is a link for the owners manual if you don't have one, It wouldn't hurt to clean the filters on the unit, probably won't help the clicking problem,
http://homeappliance.manualsonline.com/manuals/mfg/delonghi/pac160.html?idRes=12778077
Aug 25, 2013 | DeLonghi Heating & Cooling
Unit makes a loud rattling noise when operating
Hello, most likely the fan blade is either loose or cracked at the hub causing the blade to hit the fan shroud. You will either have tighten the fan blade or have to get a replacement.
Jun 20, 2012 | Kenmore 71121 Air Conditioner
Loud rattling sound coming from the "fan" main
Sounds like you have a problem with the indoor blower inside that cab. hope this helps.
Aug 13, 2011 | Honeywell ER150B Air Conditioner
Just installed a new Friedrich CP06C10 window air conditioner that I purchased from J&R. Turned it on and it makes a loud rattling sound. I installed a Friedrich CP08C10 window air conditioner in...
its the fan hitting the shroud, look inside for the fan hitting anything and check for the copper lines vibrating against each other, also, it could be the plastic front vibrating, put your hand on the front to see if you can stop it,
Apr 17, 2011 | Friedrich CP06C10 Wall/Window Air...
Central heat makes nosie
Bad bearing--or loose part rattling inside. Have checked or remove cover & check for rattle noise.
Feb 07, 2011 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Recently bought samsung multi split 3 rm air conditioner. 2 of the room air con working fine but the 3rd room fan coil seems to be blowing only cool air not like the other 'aircon' feel coolness. Got the...
doesnt sound like a gas problem. theres a vavle they opens and closes inside the unit that might be playing up either the vavle or the indoor pc board. did it ever cool ? might also be the vavle on the outside unit were not open with the alan keys so theres no gas going to them .
Nov 11, 2010 | Heating & Cooling
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Room at 84. unit set at 65. outside is 94 degrees.
I brows the web to see the specs of your unit.In that case the unit cannot cool down the room temperature, you must consider the following:The volune of the room, it might be exceeded the specified capacity, the thermal isolation of the room, must be shield from leaks,and the materials used,the absorption of the matterial at first operation, the materials around the area will absorb coolness prior to room air, and the ambient temperature outside may affect the performance of the system,If too hot outside put a better thermal isolation inside.that helps? need thumbs up... sams_Ew0rks**
Sep 02, 2009 | DeLonghi CF210 Portable Air Conditioner
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Kenmore 75085 Air Conditioner Logo
292 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
