Question about The Office Equipment & Supplies
Something is jammed in the shredder. It shreds on either side of the jam wont come out
    Top Expert:
  • The Master
  • 83,624 Answers
No real answer to this other than take the plastic case on the shredder head off and unblock it.
Posted on Mar 02, 2018
SOURCE: novitech shredder
After clearing the jam (with the unit unplugged!), let the unit cool completely, then try using it again. A notice on the nameplate inside my unit says: "2 min on/4 min off." Apparently, a thermal cutoff keeps it from overheating by automatically preventing continued operation that might otherwise melt the parts. So heed the directions. I had the same problem with my NoviTech Model PS-026/B2 crosscut shredder (max: 5 sheets, 1 credit card). Also, make sure the motor mechanism is seated square and flush on the bin. I tried testing it out of the bin, and the green ready light wouldn't come on -- for a good reason: safety. (I still have all of my fingers, thanks to that!) Hope this helps.
Posted on Aug 17, 2008
SOURCE: something is jammed
I was able to unjam an ATIVA DX 180 D shredder now the shredding blades won't turn but the motor is running.
Posted on Dec 07, 2008
  • 35 Answers
SOURCE: The shredder jammed (too much paper) then stopped
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Posted on Mar 08, 2009
rulds2008
  • 3866 Answers
SOURCE: shredder won't come on
The question would be is it getting power!!! if so the motor went bad thus causing this to fail i cannot beleave yuo shred DVD's in this even know it says it can you are still putting alot of strain on the motor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 25, 2009
JayBlair
  • 328 Answers
SOURCE: Shredder Jams with more than 1 piece of paper thickness
I have seen paper shreds build up inside the cutter housing on this model. It grows into a big tumor inside and places a lot of resistance. You will have to take it apart and clean it thoroughly. Also, oiling the cutter asm.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Sep 07, 2009
Why doesn't forward shredding work?
  • The jam was not cleared completely
  • The shredding mechanism was damaged in the process of clearing he jam
Nov 28, 2015 | Royal 150MX Cross-Cut Shredder
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
I have a corporate express shredder (CEBM6). Half way through a shredding job the overheat light came on and now the shredder wont go forward or back. I've shut it off to let it "cool" - how...
The unit requires a complete cleaning and oiling , there is paper shreds jammed at the sides.
POWER OFF AND REMOVE POWER PLUG FROM WALL BEFORE CLEANING.
Staples or Grand and Toy should have the shredder oil.
Jun 14, 2011 | Corporate Express CEBM6 Shredder
My office Max OM01287 Shredder will only run in reverse. There appeared to be a jam in the cutters and with tiny tools and very careful grabbing I seem to have cleared the jam from tiny pieces of paper. ...
There is still a shred of paper jamming the microswitch that sets the shredder into reverse to avoid an even worse jam. Find that microswitch, usual;ly on the left or right side, activated by a plastic flap on the basket side of the shredder. Clear it. As you move the plastic flap up and down you should hear it click. No click, the switch is jammed.
Mar 12, 2011 | OfficeMax Office Equipment & Supplies
Shredder screen reads door open even if the door is closed and wont let me do any shredding
Unplug it and then open i t up. You are looking for a piece of shredded paper that is stuck or jammed. Can even be a accumulation of paper dust. The piece won't be that big but most of the time that is all that is wrong. The paper either jams the door sensor or blocks it and gives the error. It can also be a bad door sensor or switch. Not very common but can happen.
Apr 25, 2010 | Universal Office UNV-38016 Shredder
I was shredding some old check books and jammed
Try soaking the clogs with hot soapy water overnight.
Soap disolves paper.
Dec 23, 2009 | Royal 160MX Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Olympia Shredder Jammed and not working
likely a spacer has broken, if you can see the underside of the cutting heads you will see a spacer or two hanging out, If this is the case the heads will have to be bebuilt or replaced.
Mar 06, 2009 | Olympia - 1452C CROSS CUT OFFICE SHREDDER
Jammed shredder
try shredding a old card, carefully but forcibly push the jammed plastic strip through the teeth.
might be faulty alignment of teeth, a factory defect!
May 07, 2008 | Aurora Electronics AS882C (Cross-Cut)...
Something is jammed
Jan 08, 2008 | Office Equipment & Supplies
521 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Julian Wainwright
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
