Question about MyGuide 3000 Portable Sat Nav Car GPS Receiver
Tevion gps model 3501 does not go to route66 when switched on,
It stops on main menu. games are ok. but no gps
You will need to restore Route 66 from the supplied cd, however before you do, check to see (using file explorer in active sync mode) if the file gps.txt is in the root directory, if not copy it from the directory "VDisc". this file points to the navigator.exe file located in VDisc/MobileNavigator. If any of these file are missing, you will need to do a restore.
Posted on Aug 31, 2009
Testimonial: "i reinstalled and it worked! thanks"
  • 27 Answers
If you can find a way to reset it than try it. but your probably going to have to send it to the manufacturer to be repaired.
Posted on Jul 31, 2009
How to fix error code 3501
if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
ENSURE YOU WAIT 10 SECONDS
1.
Turn OFF the main power switch. (Located inside machine) Leave control power switch in the on position.)
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 14, 2016 | Konica Minolta Bizhub 501 Copier
My Gps is a Go Cruise Model s350 and cannot create an account so i can put the red light camaras in
You need to remove the SD card from the GPS, format it, then copy software from the Route66 CD back onto the SD card. Take note of exactly what is on the SD card before you format it so you know you are copying back the correct data. This info was passed to me from Tempo the distributors and it worked for me. Rod.
Dec 14, 2009 | GPS
Createfile failed on INI file
Hi. I had the same problem, and i fixed it by creating a APShell.ini file wich was missing in MyFlashDisk\Shell directory.
In APShell file :
Version=1.0.2.43
Language=23
[Navigation]
Path1=\SDMMC\ROUTE66\R66n8.exe
Path2=\SDMMC\N8\Navigate8UI.exe
Path3=\SDMMC\ROUTE66\R66Navigate8.exe
Caption1=Navigate
Caption2=N8
Caption3=Navigate
ClassName1=
ClassName2=Explore
ClassName3=
Reset=
reset device and it should work.
Mar 30, 2009 | Route 66 MINI Handheld GPS Receiver
Hard reset on Route66 mini
Try updating your Route66 with the latest edition of the PND software from the R66 support website -http://www.66.com/support/index.php?cid=UK&opt=updates - This will reset the sat nav to how it was when it left the factory but you will loose your favourites and history in the process. See the website for more details.
Jan 06, 2009 | Route 66 MINI Handheld GPS Receiver
Switching maps
Can I use Tevion PWM-3501 in NZ without changing the maps?
Oct 18, 2008 | Car Audio & Video
MY GUIDE 3000 GPS Device
Try asking someone else, have you tried updateing the firmware on the gps?
Jul 15, 2008 | GPS
How to instal Tevion GPS Navigator model no. p310
i need update for a a Tevion P310 GPS
Apr 12, 2008 | GPS
MyGuide 3000 Portable Sat Nav Car GPS Receiver Logo
511 people viewed this question
Top MyGuide GPS Experts
Ric Thomas
Level 1 Expert
raysaw
Are you a MyGuide GPS Expert? Answer questions, earn points and help others
