SOURCE: i have a 1999 nissan maxima with code P1320
This code is a crapshoot. There are two main things it could be and they are both expensive. There could be wire breakage in the engine harness. There is a thick harness coming out of engine bulkhead on the passenger/right side and it has a slight bend to it. With the engine idling grab that bend and give it a couple of twists and yanks. If the engine stumbles or misses that is the source of your troubles. If not, you more than likely need to replace the coils. Any one of the six coils could be causing the code so I recommend replacing all six at the same time. You could buy one coil for the front bank and one for the rear and swap it between cylinders to see which coil is causing the code. This is time consuming but cheaper.
SOURCE: need factory wiring diagram please.
Many times the local library will have a technical section with wiring diagrams in them. Some you can even get online. Good Luck!
SOURCE: I need a wiring diagram for the spark plug wires
For the 1999 Nissan Quest 3.3L SOHC V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
......(back)......
|...1....3....5...|
|...2....4....6...|
......(front)
Distributor:
..... 2
3.........1
4.........6
......5
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
SOURCE: radio wiring diagram and car stereo wire diagram
what color wires would the constant illumination and switched be on a 1992 nissan maxima gxe
