Question about Dell Dimension 3000 PC Desktop
Black screen I think mine has the same problem but you didn't quite put enough detail in the black screen problem. When I turn my machine on it loads but then it takes me to a black screen with a _ symbol in the top left corner. I can't fix this problem because when I try to go to the F8 menu it does nothing, the only menus' I am able to access is the System Settings menu and the Boot Menu. Any ideas?
  • 45 Answers
Check your connector cables i mean board to drve and then enter the xp cd by changing the first boot device to cd-rom
Posted on Aug 01, 2009
  • 135 Answers
If you have access to some other PC, try downloading Hiren Boot CD & burn it into a CD. You have numerous utilities in this, which could be used to solve the issue.
URL: http://www.hirensbootcd.net/
Posted on Jul 31, 2009
Error code fh on maytag front loader MFW9700SQ0 have checked flow value!, pressure valve, cleaned internal filter and keeps setting code
i figured it out with my washing machine, take off the top lid (7mm 3 screws in the back) there is a black and burgundy sensor on the top left side, take off the black hose, turn the sensor clock wise 1/4 turn, lift out and blow into the part where the hose was connected to, (I did this while it was running to test it) sure enough it started draining... (its a pressure sensor i guess) and it still works so i took off the back of the washing machine and found that the black hose had a split in it. i had a compressing coupling so i cut out the bad part of the hose and coupled it back together now it works :)
p.s. the hose is about a 1/4 inch line and i think its surgical hose, and wash it out mine was filled with junk... hope it helps
May 04, 2012 | Maytag EPIC MFW9700S Front Load Washer
Where do i find the pump filter on a g eenergy star front load washer
mine was behind the lower panel, which is underneath the front door.
it comes off with 3 screws, right along the bottom edge of the machine.
the filter itself is a large, circular nylon plug, that unscrews quite easily. quite a bit of water will drain out of there, so have a bucket or basin handy, and don't panic - if there's too much water coming out, just screw the plug back in.
just to be pedantic, i put a black mark on the plug and on the housing, so i would know how far to tighten the plug when i put it back. (it's not good to over-tighten plastic parts.)
Sep 17, 2011 | GE Energy Star WCVH6260F Front Load Washer
Briefly: laptop cant turn on Detail: After pushed power button, the note book didn't turn on. Screen kept black. Power button didn't light on(usually should). The laptop is without any sound...
The first solution I'd recommend is removing the battery and then trying to power on just with the AC adapter. Why are you afraid to remove the battery? no data will be lost.
It maybe that you have a dead motherboard or that there had been a power failure while you were putting your machine to hibernate.
Jul 03, 2011 | Computers & Internet
Samsung Tocco Lite says ''download'' on blank screen
I turned it off, then took the battery out for 5 minutes then put in back in and turned it back on, this should work, however for me it didn't so i turned it off and on again on doing this it went to the normal loading screen
Jan 27, 2010 | Samsung Tocco Ultra Cell Phone
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Janome 90000 just quit no light or enything help me please thanks Kathy
Did you check the dial inside the thread area, I was wiping some dust off mine and some how changed mine and when I turned the machine on my screen was totally black, But the know is black and only partially sticking out.
Aug 27, 2008 | Janome Memory Craft 9000 Computerized...
Power is on but screen is black
I found this [temporary] solution at http://www.wiierror.com/wii-black-screen.php:
(via email, thanks Steven) This happened to me once, but I fixed it. Here is how:
Eject the disk
Unplug the wii at the back
Wait 1 minute
Plug it back in
Turn it on from the remote
Press reset if it does not show up
Hold the power button to shut it off
Turn it on once more.
I don't know how, but it seemed to work for me. The problem happened when I was trying to load the Mii channel. Hope this helps !
(via email, thanks Andrew)
The first time I shut down my Wii, the light went orange (as it should). When I turned on the power with my wii remote the next day, the wii\'s light turned green but the screen was black.
The treatment was the same as from Black Screen, No Connection: Unplug the Wii\'s power supply unit, then replug; turn system on with wii remote.
The difference is: this problem can strike in more places than just by loading the Mii Channel. Also, I think the green light being on (yet there being a black screen) is a common symptom as well.
May 18, 2008 | Nintendo Wii Console
Can't even turn the stupid thing on. Turns itself off when I do.
i think that's really the problem with motorola V3x coz i hav d same problem here in saudi arabia where i bought mine. i'm thinking of going back to nokia again. motorola sucks..
Apr 10, 2008 | Motorola Mobility RAZR V3x Cellular Phone
X-box 360 problem
Your lucky, one person on YouTube had the same message(E64)
Some people commenting on the video had this to say about it:
1) "I think this happens when you start a corrupted file (a demo or somthing) because thats what happened to mine. I took off the hard drive when I was downloading BioShock demo. the 360 was off though"
2) "hey buddy, had the same problem... just dont put it in such an area... there is not enough air! hope it wont break another time!"
Then there is someone who says to try this trick:
"BUDDDY. try doing the Towel Trick. it works on mine"
Here's the towel trick:
utube.png You-Tube video "avWs4-wD15w&rel=1" placeholder (do not delete) utube.png
Dec 14, 2007 | Microsoft Xbox 360 Console
When I plug in AV cable for playback on TV camera screen goes black
did you fully charge the battery before use when you bought the camera? and is it charged now? most cameras can take photos but not be able to hook up to download. because photos take less energy it may be that it has just enough energy to take a picture, but not quite enough to do anything else. i don't think your stupid, its just that some people don't think of the little things as be possible. also could check to see if there is any obstructions. (dirt, little pieces of plastic, etc.) on the main routing items. (memory card, plug-both ends, inside the camera housing itself). hope i could help GOOD LUCK!
Apr 08, 2007 | Olympus Stylus 710 Digital Camera
Dell Dimension 3000 PC Desktop Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
