Question about HP iPAQ H1910 Pocket PC
Saving music on my micro sd..
Can i save music to my micro sd card and put it on my  phone?
after uploading songs on a sd micro card, how do i get the music to play in my phone using the card. i placed the card in the slot and it doesn't do anything.
Re: saving music on my micro sd..
The only way the music can be played on a cell phone is if it is in mp3 format. you also have to list the songs individually (they cannot be separated into folders). to listen to the music you should have some sort of music player on the phone that will play the songs.
Posted on Dec 07, 2008
0 characters
3 Points
My new SciPhone i68 does not recognize the memory card.
when i put my micro sd into my sci phone and then go to documents it is not there it says just the phone memory. how do i format the memory card to my phone or even to get it to work ?
Feb 22, 2010 | PDAs
I own the r451c which has an mp3 player, but when i insert the micro sd and go to music player, i get a prompt that says no mp3, what am doing wrong
You have to load mp3s on the micro SD card via the computer. To do it properly, you must place the mp3s in the folder that says My_Music which is located in the micro SD card. That folder is created once the micro SD card is first inserted into the phone.
I hope that helps.
Jan 03, 2010 | Samsung BlackJack II Smartphone
Putting music from computer to micro sd card then to phone
you have to tell it to look in the sd card not the stock folder
You can put it on the card with an adapter or hook up the phone with it in and it will show up as an external drive then just drop the music in then
Aug 07, 2009 | Motorola Mobility A1200
Micro SD card wont work
Try Formating the 1gig chip in 'Fat' not Fat32, then put it back in phone,, should work then.
Also the phone aparently will only recocnize up to 2Gig (But U need a Firmware upgrade)
Hope That helps!
May 23, 2009 | Palm Treo 750 Smartphone
Saving pictures on a pantech duo
Yes, if you want to transfer pictures, music, etc to your new phone you will need to purchase a micro SD card. Make sure it is 2 gig or smaller though, as the Pantech Duo will not read anything larger.
May 08, 2009 | Pantech Duo Smartphone
I have a sd memory card problem
click start then my stuff click menu then click storage card then you're into your storage card
Dec 16, 2008 | Pantech Duo Smartphone
Sidekick 2008
  • uuuhhhhh the only way that iKnow how to do it iz with an Micro SD cKard bro.
  • u wouild have to drag and drop or save all of your musicK to the DciM folder on your MMc
Oct 27, 2008 | T-Mobile Sidekick
Download to BlackJack II
What format are the itunes songs in? The Blackjack II will read WMA, MP3, and a few others but not itunes format.
The easiest way to get music on the phone is by putting all of the songs onto a memory card (Micro SD) and then put the memory card into the phone.
Jul 10, 2008 | Samsung BlackJack II Smartphone
Blackberry curve ringtones
You cannot save a ringtone, picture, or music to a SIM card. Those files get saved to the "hard drive" of the phone. In order to get music into your phone to use as a ringtone, you must either
1. Download through one of those pay for services like Jamster or through t-zones or the like.
2. Use a data connection plan to download from the "mobile net". Sites are free that let you upload your music to an address that you can go to on your mobile web and download to your phone. The phone usually knows where to download the ringtone to on its own. T-mobile's t-zones costs $5.99 a month for the mobile web.
3. Use a USB connector and the media managing software for the phone to transfer the file to your phone. The Motorola RZR uses a software called Motorola Phone Tools to do this. The Blackberry also has its own Blackberry User Tools Software. Usually, the software shows you the "folders" on the phone and one will be called "tones". You put it there and it comes up in your list of ringtones.
Jun 04, 2008 | RIM BlackBerry Curve 8310 Smartphone
Music player
everytime u put new music onto ur memery card it says updating because it has just got new music on it sometimes the music saves onto the memory card click onto ur memory card see if all ur music is in there sometimes when we put too many songs on the phone it takes abit to update as theres so many new songs going onto it
May 14, 2008 | Samsung SGH-U600
HP iPAQ H1910 Pocket PC Logo
265 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
