Installing an App on your 2016 Smart TV UN
See if the process in the link above will allow you to add the Netflix app.
Good luck.
Semper Fi,
Z
SOURCE: netflix problems
maybe this can help. If not, please supply your TV model.
You need to register with Netflix online first to create a login and password.
Here`s how to:
>> On your computer go to netflix.com then click signup or signup.netflix.com
>> Fill all the necessary information they needed.
>> Purchase any plan they offer after you created an account(Optional as you can avail a trial version for 7 days)
Now go to your TV
>> Turn the TV on then hit menu
>> Go to My apps menu
>> Select Netflix
>> Sign in with your username and password
>> Take note of the code
>> Go to your computer and login to netflix.com/activate and type in the code to activate.
>> Go back to the TV select finish to start the service
Important:
Make sure your TV is connected to the internet, either wired or wireless
Here are the three methods to connect wireless on your TV:
Scan and connect
>> Turn on the TV
>> Go to Menu
>> Go to Network settings
>> Select easy then scan for networks
>> Select and connect
Connect using WPS
Press the WPS button(Padlock with signal wave) on your TV`s side panel then on your router.
Note:
You only have two minutes before the router turn the WPS off
Add network manually
>> Go to Menu
>> Select manually add network
Type and select the appropriate settings:
SSID: Name or the Wireless network
Security: Either the WEP, WPA, WPA2 or WPA+WPA2
Passphrase/Passkey: Type in the password
Wait for a prompt that the TV is connected to the internet.
You can buy a Blu ray player that has net flex on it. Then what ever TV you hook the player to you will have net flex but, you have to pay a monthly bill for net flex.
SOURCE: How do I register my Samsung smart tv on amazon prime
Please contact Amazon on this. they can be called at this number.
1-866-216-1072
SOURCE: Anyone there
https://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Please visit these sites to get some details.
I Could help you more if I knew the Model Number of your Samsung Smart TV.
But to be short, try checking the audio menu of your television, and turning off internal speakers and switching the audio to external output. The smart TV should detect the kind of audio system you have connected to it.
