Question about Car Audio & Video
Can i hook two sub up to a 1 channel mono block amp
    Guru:
  • 256 Answers
Yes you are able to connect two subs. You wil have to make sure of the connections though. Put your two speakers next to each other face down. You will notice that your speaker connectors follow in sequence (+ -) and (+ -). (or the other way around) Connect one wire coming from your amp to the first +. Now bridge the speaker connections in the middle (- to +) and the last - goes back to the amp.
Posted on Jul 31, 2009
I have 2 sony xplod 4ohm subs rated 350w rms and 1200w max, i have them in really shallow boxes because i drive a single cab toyota, i know these subs **** but i do also know that they can hit alot harder...
the premier amp is better since it has a better rms rating (360w total or 160w each sub) than the eclipse (280w if you bridge all 4 channels which isn't possible but 140w for each speaker bridging 2 channels per speaker). Neither are going to push your subs but if you get another amp wiring kit and use one amp per sub they will sound a lot better and you could just hook both power wire and ground wires from the bridged channels to the power and ground terminals for the sub. That would be my suggestion since the subs are rated at 350w and each amp is 280w and 320w which will push but not blow the subs.
Aug 17, 2010 | Sony Car Audio & Video
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
What would be the best amp to push 2 kicker 15 L7s
find the ohms on each subwoofer and how much it can handle. If you have two 4 ohm subs get a powerful MONO AMP and hook it up in parallal. If you have two 2 ohm subs get a (1 ohm stable) Powerful MONO AMP and hook it up in parallel or a powerful 2 CHANNEL AMP but the wiring can be a little complicated cause you've got to connect the subs in series and bridge it on the positive of 1 channel and the negative of 2nd channel for maximium benefit without burning out the 2 channel amp. If you got two 500 Watt subs then you got to find an amp that can put out 1000Watts anything less wont sound good and may burn out the subs because of too much distortion cause of lack of power.
Apr 06, 2010 | Phoenix Digital PD-397 Car Amp
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
How do i wire 2 4ohm single coil subs to a 2 channel 6ohm load?
If you can setup the Amp as a Mono Amp this will work for you very well unless the Amp needs a 12ω Load when setup for Mono Operations. You will want to hook the Two Subs in Series so that the Amp will see 1 8ω load. This means you will hook a wire to the Positive pole of one Sub and hook the Negative Pole to the Positive Pole of the Second Sub and hook the Negative Pole to the Amp's Negative pole. This will reduce the overall output but will end up having better reliability of the Sub since each sub will only see ½ the overall output of the Amp and you will still get the full output of the Amp.
Oct 16, 2009 | Kenwood KFC-W300S Car Subwoofer
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
Jan 13, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
2 ohm dvc and monoblock sub amp
Yes. When you run two-two ohm subs to a monoblock amp its on the same channel meaning there ran parallel, and that makes it one ohm and most mono-blocks won't read one ohm. Are you popping fuses in the amp?
Apr 02, 2008 | Audio Players & Recorders
Car Audio & Video Logo
180 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
