Question about Arnold Corporation Arnold/MTD 22" Lawn Mower Blade #742-0125 #MTD-22
How do I know if installed the v-belt properly for an MTD 22" self-propelled mower #12b-264c062. The belt has been installed around the engine and transmission pulleys and behind the belt keeper. does something need to occur near the engine belt keeper bracket? When the drive blade is engaged the front wheels do not turn? The belt is awfully loose even when the drive control blade is engaged? Do I need to adjust the driver control cable - if so, how do I do it?
  • sozamikej Jul 31, 2009
    This is a clarification to the above questions (Guru).
    The MTD 22" is a self-propelled push mower and the model number is 12B-264C062.
  • s_s_m_o_k_i_
    s_s_m_o_k_i_ May 11, 2010
    Is this in reference to a riding mower or push mower? and is that the serial number or model number?
  • 45 Answers
You need to check the owners manual. And be sure you have the correct belt.
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
Posted on Aug 25, 2009
No sprk 6.5 brigs and straton self propelled white outdoors mower
remove the upper cover from the engine then unplug the small wire from the side of the coil then look for spark if still no spark the coil is bad
Aug 15, 2012 | Mtd 22" White Outdoor Self Propelled High...
How do u change the belt on a self propelled MTD Model #12A-268B352 push mover
Please follow this link to the MTD website which will give you step by step instructions. I hope this works for your model as well. Best of luck to you and "Happy Motoring". James
http://tinyurl.com/3vpwdts
Jun 27, 2011 | Mtd 22" Yard Machine Push Mower
How do I know if I am replacing my mtd rider mower belt correctly
The rule of thumb for the routing of the mower belts is to make sure the "V" inside of belt is fitted into your pulleys. The "FLAT SIDE" outside of the belts rides with the flat side up against your idlers (lookes kinda like a pulley but is wider.) It might take you a couple of attempts to get it right. When the belt is on properly it will be nice and snug.
Good luck
roundo4
May 23, 2010 | Mtd 22" White Outdoor Self Propelled High...
I have a self propelled MTD Model #12AV55DQ513
CONTACT A LOCAL MTD DEALER. GOOD GUESS WOULD BE 100.00
Sep 21, 2009 | Mtd 22" Yard Machine Push Mower
How to remove old and install new blade adapter (753-0609)model 759 on MTD mower--
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time
Sep 07, 2009 | Mtd 22" White Outdoor Self Propelled High...
Need instructions how to install belt on self propelled craftsman push mower
raise the front of your mower up and support it with something safe like a jack stand
take the blade off
when your blade is off locate the plastic cover covering the belt and remove
now remove the belt but first remove the plastic cover on top of the mower to uncover the gearbox that turns the wheels your belt goes from the engine pulley to the gearbox pulley
you will have to work the belt off the pulley while turning the motor by hand or the same when installing the belt.
to install belt reverse the procedure.
hope this helps some
Jun 06, 2009 | Mtd 22" White Outdoor Self Propelled High...
Arnold Corporation Arnold/MTD 22" Lawn Mower Blade #742-0125 #MTD-22 Logo
258 people viewed this question
Top Arnold Corporation Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Arnold Corporation Garden Expert? Answer questions, earn points and help others
