Question about Brother HL 2140 Laser Printer
Printing i can't print a document
    President:
  • Brother Master
  • 1,447 Answers
Please send me details error cod or actaual problem
Posted on Jul 31, 2009
Word 2010 doc will not print. Will print with Wordpad.
Microsoft support describes several things to try. After checking to see if any new blank document you create could print or not, the next possibility is to rename the normal.dotm file that may be necessary to resolve this problem.
Procedure to check:
"Microsoft Windows 7
  1. Quit Word.
  2. Click the Start button.
  3. In the Search Programs and Files box, type Normal.dot or Normal.dotm depending on your version of Word.
  4. For each occurrence of the Normal.dot or Normal.dotm template that you find, rename it Normal.old. To do this, follow these steps:
    1. Click Normal.
    2. On the File menu, click Rename.
    3. Type Normal.old, and then press ENTER.
You can now print new documents that are created from the new global (blank document) template (Normal.dot). However, existing documents that were created by means of your old Normal.dot file may not print. If this is the case, go to the "Print the problem document" section to resolve problems with these documents.
If you cannot print this new document, there may be a problem that prevents Word from printing. If this is the case, go to the "Print the problem document" section.
Determine if the problem documents were created from the same custom template You may still not be able to print particular Word documents. Examine the problem documents to determine if they were created from the same custom template. To determine which template created the problem document, follow these steps:
Word 2010
  1. Open a document that you cannot print.
  2. On the Developer tab, click Document Template in the Templates section.
  3. On the Templates tab, look in the Document template box."
Jan 12, 2018 | HP Office Equipment & Supplies
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
I have a canon pima mx340 printer/fax machine. How do you get a stored fx to print out
Printing a Memory List or Specified Document in Memory
1. Load paper.
2. Press the FAX button, then press the Menu button.
The Fax settings screen is displayed.
3. Use the button to select Memory reference, then press the OK button.
4. Print a specified document or memory list.
· To print a memory list:
Use the button to select Print memory list, then press the OK button.
The memory list is printed.
· To print a specified document:
1. Use the button to select Print specified doc., then press the OK button.
2. Use the Numeric buttons, or the button to select the transaction number (TX/RX no.) of the document you want to print, then press the OK button.
3. Use the button to select Yes, then press the OK button.
If you select Yes, only the first page of the document will be printed. If you select No, all the pages of the document stored in memory will be printed.
To print other documents, repeat the procedure from steps 2 to 3.
Nov 08, 2010 | Canon PIXMA MX340 Wireless Office...
Will not print adobe documents, prints other documents, please advise
This is assuming you mean Adobe Acrobat:
I have worked in a University and now work in a large state agency and have found that this can occur when people accidentally print to document instead of to a printer. I know it sounds silly, but please give it a go:
  • Try using the print icon print.jpg on the Acrobat tool bar (rather than your browser's print function). On the print dialog box that appears, make sure that the option to "Print to file" is unchecked.
  • If print icon is grayed out, it may mean that the document's security prevents printing.
If this does not work, please give me some additional information (such as which product/version you are using and what kind of document you are trying to print) and I will try my best to assist.
Hope this helps.
Jan 30, 2010 | Computers & Internet
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Printing document
Did you change the top margin setting?
Make sure that the paper size is correct in the printer settings of the control panel when you print. You have to tell it what size paper you are printing on.
Aug 15, 2008 | Sharp AL-1551CS Copier
Brother HL 2140 Laser Printer Logo
73 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
