Phone will not turn on, I went to turn phone off to re-boot because it wouldn't dial and now it won't turn on. i put the battery in and hit the power button and the motorola symbol comes up but the phone won't turn on the rest of the way
  • Linda Emmery May 11, 2010
    You might need a new battery or a software update.
    Problem Solver:
  • 13 Answers
Complete a hard reset as per the manual - this will override most of the problems encountered.
Posted on Aug 28, 2009
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspire™ T180 PC Desktop
I was putting in a new car stereo and when I went to start my car it wouldn't start. I got a jump start from a friend and that did nothing as well. I did hear a little zap when I put in the stereo...
check it out with a multimeter ,but i think your jump leads may not be any good and you have just flattened the battery ,but check the big fuses in the power distribution box under the bonnet
Aug 01, 2011 | 1991 Volkswagen Passat
2004 Sante fe 3.5L 2WD went out to go to work and wouldn't turn over, (assumed dead battery), went down and got new battery and installed, still wouldn't turn over, (assumed starter shot),removed...
TEST POWER LEADS TO STARTER FOR POWER
AT STARTER (BATTERY POSITIVE TO STARTER BATTERY NEGATIVE TO ENGINE BLOCK)
THEN TEST FOR SIGNAL POWER TO SELENOIDE ON STARTER
(KEY TURNED TO START POWER SHOULD GO TO SELENOIDE)
IF NO POWER TO SIGNAL WIRE CHECK FUSES AND RELAYS
ON STARTER CIRCUIT
IF THIS CHECKS OUT MAY BE AUTO TRANSMISSION NUTRAL PARK SWITCH
TRY TO START IN NUTRAL OR WHILE SHIFTING TRUE GEARS SLOWLY WITH SHIFTER
IF STANDARED CHECK NUTRAL SAFETY SWITCH
May 08, 2011 | 2004 Hyundai Santa Fe
My phone dials too fast. The only way I can dial a number is by taking it off the hook and manually dialing after I hear the dial tone. If I use Caller ID, redial, directory, or putting in the number...
I had the same problem with a model 6325-4. Worked fine for the first week. Then, tone dial with redial, directory, etc was too fast for system to register the number.
Called Vtech support. After a 15 hold, 5 minute explanation and tech listening to a reproduction of problem over the phone, she asked that I perform a complete system reset (I called via my cell).
I unplugged power from base first, then removed battery from all hand sets. Powered down for ~3 minutes (with tech waiting on line the entire time).
I powered up base first and then reconnected all handsets. Selected a handset at random and performed the same dial from directory test I had done just before power down. The thing worked again. Call went through just fine. Tried several other selections in directory with same positive results. Now, if the system just stays stable and working.
Hope this helps..
Dec 19, 2010 | Vtech CS62192 Cordless Phone
I hit a button on phone, screen went blank, not able to dial. I put in the charger and it is fully charged
If battery is charged and phone is working simply do this: Press the power button for a few seconds, which is the same as the "hang up" button with red ink on it). Voila! It took me serveral days and a number of dealers telling me I had to pend $300 for a new phone before I uncovered this fix.
Feb 16, 2010 | Panasonic KX-TD7896 Cordless Phone
Phone won't turn on, took battery out and put it back in, still won't turn on, it acts like it's about to turn on and then blinks back off. Battery is charged up, I've only had it for 4 months
When you power up first let it going into off chargeing mode, then hold the power button to turn it on, continue to hold it through this whole process, then after the sitck together box has been completed (which may take a few attempets) rapidly push the right soft key until your phone jump in and out of the t-zones area which should be your default right soft key buttong then you should be able to use your phobe normally, note that it did take me a good half an hour of doing this to make my phone through the whole process. :)
Nov 04, 2007 | Samsung SCH-u340 Cellular Phone
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
