Question about Krups XP7230 Compact Super Automatic Espresso Machine
My Krups coffee maker is leaking some coffee onto the counter. The fluid is coming from above and behind where the coffee normally should be coming out. Any easy fixes or do I have to send it in?
  • karl_moen Jan 06, 2017
    It might be worn o-rings on the cylinder head for compressing the coffee grinds. Take off the top panel and release the cylinder. it should be possible to take it out. Replace the o-rings. May also be an idea to remove the front and side panels so you can clean out the coffee in the bottom.
    Brigadier General:
  • 4,090 Answers
No normal fix it requires worshop inetervention to replace the seal
Posted on Jul 31, 2009
Gaggia accademia
Most likely a connecting pipe might have come loose or leaked, boiler leaking might also be possible
Jul 17, 2014 | Gaggia Coffee Makers & Espresso Machines
Coffee winds up on the counter
Replace seal MS621749 above the filter handle
Sep 16, 2013 | Krups XP1020 Espresso Machine
Krups xp 4050 leaks water under unit when sitting on counter
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Jun 13, 2010 | Krups Small Appliances Espresso Machine
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter:
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Coffee leaking onto to counter top
I've worked on that problem on a X9, I am not sure if the coffee/milk spout is the same but, I had to dismantle the spout and clean inserts, I also had to replace the o-rings on the spouts.
May 17, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Krups XP2070
if the water is leaking from the back left side of the unit then the seal/valve to the expresso water container is lose and leaking. you can either go the warranty route or open the back up and tighten the two screws holding the seat/valve in place.
Jan 03, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP4020
The coffee holder is just hanging in place, not secure against the seal as it should be. Make sure the coffee holder is secured flat up against the seal before turning the handle and locking it into place.
Apr 18, 2008 | Krups Allegro FND111 Espresso & Coffee...
Coffee maker side will not work.
check inside for broken or burnt connectors going to the heater element. these are normally slide in spade connectors.
Sep 10, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups XP7230 Compact Super Automatic Espresso Machine Logo
1,495 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
