Question about Mintek Televison & Video
Digital Audio with the Mintek DVD-2110 DVD player
I own the Mintek DVD-2110 DVD player. I tried connecting a coaxial digital audio cable to the digital output on the DVD player to get 5.1 sound. There was no sound and I checked the settings on my AVR and that does not appear to be the problem. I tried the settings on the DVD player but could not find anything to turn DTS or digital sound on. Is this a settings issue on the Mintek? Do I need to change something to get the digital audio output to work? Thanks.
5 Suggested Answers
SOURCE: dvp5960 hdmi set up issues
You can disable the digital audio output in the audio tab at the setup menu.
Posted on Jul 13, 2008
SOURCE: Denon DVD 1000 & DTS playback
wheres the question
Posted on Jan 31, 2009
  • 88 Answers
SOURCE: my marantz DV 9500 doesnt output digital signal
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Posted on Aug 11, 2009
  • 50 Answers
SOURCE: need password for Mintek dvd player model #2110
try reseting it
Posted on Nov 24, 2009
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Will a DVD player that only has the red white and yellow cables produce 5.1 surround sound or must the DVD player be capable of being connected with an HDMI cable
Nope. Just analog stereo and composite video. The player and receiver must have a digital audio path (HDMI, coaxial digital audio or optical digital audio.). The HiDef video would be available on HDMI or Component Video.
http://en.wikipedia.org/wiki/Digital_audio
http://en.wikipedia.org/wiki/Component_video
Jan 31, 2011 | Audio Players & Recorders
Can the sony bravia home theater system be surround for both dvd and tv?
Strickly speaking about the audio:
The unit has digital audio in on 1 each coaxial and digital connectors.
Most DVD players have digital audio out in either a coaxial (RCA-looking) cable or optical cable.
Consider this: your TV is not a Source of audio (or even video, if you think about it). You probably get your programming from a cable or satellite box, Its audio should be available digitally.
If your DVD and cable use DIFFERENT types of digital audio sources, you're in luck. Attach each one to its compatible input on the Bravia. If you only have two optical outputs you can only attach one at a time.
If you have only two COAXIAL digital audio sources you CAN combine them into a single digital input on the Bravia by getting an RCA-splitter cable to connect them both to the one connector. It will only work if you leave one source dormant or off at any time you're monitoring the other source, otherwise you'll have two digital 'converstions' going on with the Bravia at the same time and it won't be pretty.
Dec 14, 2010 | Sony BRAVIA® DAV-HDX277WC Theater System...
Adding another device to the system
Well, if analog works for you connect the CD player's analog RCA cables to the VCR inputs.
Can you imagine why you NEED to have the TV audio coming into the receiver from the TV? Are the TV's audio system or speakers superior to the audio section of every other source of TV-related programming? We hope not. Does the TV receive any programming that the receiver can not? Maybe games. I imagaine this MIGHT justify running analog TV audio back to the receiver.
Your cable box and your DVD player have both digital and analog audio outputs. The gray area is what your TV has for audio inputs. It could survive with simple RCA analog audio in from both and none to or from the receiver. Then you could watch Lo-Fi cable and DVD's without the receiver turned on.
That would free up the TV analog audio input for other things.
I imagine your DVD player is using one of the digital inputs on the receiver. If you have one each optical and coaxial audio output among your DVD and Cable Box you could place them in the two available diigital inputs.
Now, what about the CD's digital output? For stereo music you're not likely to be able to hear any difference between it and the analog input BUT it can still be connected digitally IF it has a coaxial output. Coaxial digital inputs can be shared.
Get an RCA-splitter and join the two units entering the coaxial audio input just before they enter that connection. Either will work just fine if you TURN THE OTHER ONE OFF when you want to us it.
Mar 19, 2010 | RCA RT2760 System
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
Dvp5960 hdmi set up issues
Apr 11, 2008 | Philips DVP5960
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
HS-R430 System
Connect the audio cable (red & white) from DVD player to the Audio DVD in (L/R) of the receiver.
Change the source selector to DVD.
Incase of coaxial o/p from the player, connect it to the coaxial i/p of the receiver. Then select the digital i/p button twice located in the front of the receiver.
Nov 19, 2007 | Onkyo HT-S680 System
Televison & Video Logo
66 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
