Question about Poulan Pe550 Gas Edger
How to change the spring that controls the pull cord on the Poulon Weed Eater Gas Edger PE550
3 Suggested Answers
SOURCE: Weed Eater PE550 - How do you change the spring
Lay the unit on it's side, carborater down. Removed the 3 screws holding hold the gear assembly housing. Hold the clutch assembly inside a cloth with a wrench and remove the nut. Left from the starter cup as a stack and set aside. There is a starter retaining ring on the shaft. Pull this with a long nose plyers. If it spings free, it is easy to loose. Then left out the starter pully. The starter spring is under the pully. Remove it with a sharp pointed tool. A broken one is crusted in rust and will be snapped off inside the coil.
Posted on Sep 24, 2010
trayhan05
I recently change it though i can not by own. I have fixed it where from i bought it . you can try same way
10 Best Hose Reel 2016 Reviews And GuidesGardening Easily
Posted on Dec 01, 2016
To change the blade which way does the nut turn to get it off? Clock wise or counter clock wise?
Most weed eaters are opposite to conventional thread. So they are CLOCKWISE to take off
Apr 30, 2016 | Weed Eater PE550 8-1/2-Inch 22cc 2-Cycle...
Pull cord on weed eater won't engage
If the pull cord does not turn the engine over, the starter pawls are probably not working properly.
Jul 13, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a PE550 Weed Eater Edger and have new carb, new fuel lines, new ignition module, new gas filter, new gaskets, and new air filter.... and it still won't start, what should I do now?
Theres a screw for gas and air mixture on it you need to turn it all the way in then turn it 1 and a half times out , its a perfect factory setting the push primer 3x and turn on choke pull 2x then turn off choke should run hope this
Sep 28, 2013 | Health & Beauty
How do I change the blade
The blade bolt is normally 9/16, you will need a good socket and long tommy bar to remove the bolt, an impact wrench will take it out very quickly if you have or can borrow one,
Jun 16, 2012 | Poulan WEED EATER PE550 711431 22CC 2 Cyc...
What is the oil ratio for the poulon pro link weed eater
Hi brochon
Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How to change the spring on my Poulon Weed Eater PE330
Hi there, Please clarify the exact model of your machine. I't appears that Poulan doesn't have PE330 for their weedeater models. Thanks, Jeep Brainy
Jul 31, 2009 | Garden
Weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
Jun 28, 2009 | Poulan Pe550 Gas Edger
Where can I find a manual for the PE550 weed eater
You can download one online at... http://www.poulanpro.com/poulanpro/indexAction.do?id=default Scroll down the right side to 'Download Manuals'...then enter your model #.. you can then download the owners manual or parts manual. Dwain
May 21, 2009 | Poulan Garden
Poulan Pe550 Gas Edger Logo
347 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
