The Wall Heater is about 13 years old but has worked well until now. We did have someone look at it I Think he put Gas or something in it. well that worked for about one hour and that was that. He did say that we would probably have to replace the one we have with a new one. Is that true.
  • Gloria Bourke Jul 31, 2009
    Hi Taran,
    Hey thanks for your advice I will cretainly go with it. It looks like I will be buying a new one. Thanks heaps though, everything you pointed out was so informative very much appreciated Glory.
  • 10,515 Answers
There might be many reasons for the non working condition. As it's almost 13 years old, Gas is the main suspect. You already put that and it does not work.
Now,
Note - I am taking into consideration that Gas is not a problem. Make sure there is no Gas Leak.
The other 2 main suspects are :-
1. Thermostat
2. Compressor.
If thermostat is an issue, better to get it changed and if compressor is an issue, better to change the wall heater as it would cost you many bucks to repair and specially spending so many bucks on such an old wall heater is not a wise option.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 31, 2009
Need gas valve for Empire 7088-2 (Nat Gas) heater
Get on computer and type in surplus gas heater valves,or used,or gas valves for --name and # of valve,i can't find the name but there's a Canadian co.that almost has everything gas..years ago they bought up a lot of American companies stock when going out of business of changing product types,there's got to be other companies that have done the same,,ask the wikipedia of out of business gas companies,who bought them out or there parts,someone has them,or a universal valve.
Nov 22, 2012 | Empire Heating & Cooling
Internal 1/2 psi propane regulator is not passing gas thru so that heater wont light. Are there recalls? Where can I buy a replacement part? Heater is 2 years old, never lit.
What's the pressure to the heater? It should be a minimum of 11 to 13 water column inches. Also, make sure that your heater is in fact a propane fueled heater. Don't go by whats on the box it came in. Look at the manufacturer's tag(s) on the heater. It may be a Natural Gas unit instead of Propane unit. I've seen this happen before. In which case it won't work and can not be converted.
Feb 02, 2011 | Dyna-Glo D-E37 Wall Mounted Panel Heater
I have an older rental home that has a wall heater, house built in 1960 and I need to purchase a cover, the dimensions are 18 1/2 x 70 inches HELP.
im sorry but you cant get a new cover for a unit that old the best you can do is try to find a used one mabey put a ade in the paper someone might have an old williams heater that dosint work inymore and might sell a cover to you.
Jan 21, 2011 | Williams (5009622) Ceramic Gas Wall...
I have had problems with my Cozy gas wall furnace since it was new (its about 6 yrs old now) I won't stay on. It seems that every year I have to call out service people to get it to work. It always...
if the switch at the top of unit is tripping there is something wrong with the vent , the switch is set at 350 degrees it detects back draft do to a improper vent or blockage of vent, if the installer use the old vent system that is more than likley the problem, have the installer call Cozy tech line at 502-589-5380 so they can go over how the unit is installed.
Dec 07, 2010 | Cozy (W352E) Heater
My wife want's to move the furnace to an inside wall. It is presently mounted to an outside wall venting directly outside. where she wants to move it is directly under an old flu for an old heater. can the...
it can go up but is designed to go up wall cavity and unit i supposed to sit with it's back against wall to adapt to a flu that is already there would mean you would have to sit out into room a little bit which could look funny, the only way i can think to do this and look good would be to make a false wall for flu so upou don't see it and it wouldn't have to be built to far into room only far enough to hide flu i would stringly recomend someone to come have a look at it for you as it is acchievable but to make it look half descent if not immaculate job would be to get a specialist on fluing to look for you and advise on options to get it to go to old flu outlet may be something you can do but i don't think it would be a good idea as you would have to either bring heater far enough forward to go straight up it as wood heater flu would have been a fair distance of wall for clearance's, or the other way would be to bring flu behind heater then elbow out to get over to old flu exit, so get someone to look at it for you as you want to also put into a place where it will heat efficiently too!
Nov 23, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Natural Gas wall heater
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Dec 22, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Nat gas wall heater wont come on during nite
Definatly sounds like a bad ground circuit IReplace thermostat you want it to be reliable
Dec 21, 2008 | Heating & Cooling
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
I bought a home built in 1935 with a Perfection Brand gas forced air heater, any info or a website on this old brand of heater would be greately appreciated. I was told it is over 25 years old, I just want...
any and i mean any ac and heat company you call in the yellow pages can and will be happy to repair yor heater. parts are all generic. problem is the heat exchanger needs to be tested every year with a co detector so no one gets killed. thats pretty blunt but hey its true. gas is nothing to play around with.call the gas company and they will usually test it for you. maybe for free. all heaters work the same. stat says heat , if pilot is lit then thewrmocouple senses heat and oks main gas valve to open then burner lights and a while later blower comnes on and blows hot air into house. question is , are air and chimmney gases mixingin furnace? test with co detector.does flame lift on burners? observe and compare with your previoys observations. my gut feeling is that consummer reports says 9 to 13 years is a life span on a ne wunit , your messing around with a old piece of equipment. it doesn't care about your finances, it will fail and harm you when its time comes reguardless ....
Oct 12, 2008 | Heating & Cooling
Rinnai RHFE-1001FA
I can suggest a around-about solution. I also have the same model installed around the same time. I have the outlet that it is connected to controlled by an electric heat thermostat on a wall at the oposite side of the room. I keep the heater on high at all times and the thermostat controls the electricity to the outlet. It's worked great for the 13 years it's been installed.
Mar 11, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
