Question about Cell Phones
My i9 phone is acting wired. It started automatically taking picture and i could not get out of that mode. no other button would respond please help! I even took the battery out and the sim card. when I put it back on after about 10mins. it was ok but then again it started again.
  • 55 Answers
Your phone has been effected by the virus. try to use an anti-virus and if you dont have an anti-virus in your phone then connect it to the pc and then use the antivirus. scan it n remove the virus.
Posted on Jul 31, 2009
My rebel xti will focus but not take pictures
there is not much to do by yourself, sounds like an electronic problem, please refer to next service center.
Oct 18, 2011 | Canon EOS Digital Rebel XTI Digital Camera
Good day! I have a Canon MX-328. I was expecting to receive a fax so I read the manual and I set my printer to Tel priority mode since we only have one phone line mostly for voice calls. According to...
Hello.
You have explained your question with very good detail
Press the colour button, then hang up. Most faxes are capable of transmitting colour faxes, and you should press the colour because even if the sender sends a B&W Fax, it will Automatically receive it in B&W. If they send a colour fax and you hit the B&W Button, it will only receive in B&W.
I hope this helps, if so please rate this answer below Thank You for supporting the FixYa Community
Regards GM
Apr 25, 2011 | Canon PIXMA MX300 All-in-One Printer
Olympus sp565 shutter button is malfunctioning
I will second that. I can't seem to find a solution for the exact same problem. I tried to take a picture but does not respond, If I take the batteries out and put them back in as soon as I turn it on it takes a picture, then doesn't respond again. AHHHHHHH. Ive only had this camera for about 18 months and I'm so disappointed. I had a fujifilm 5600 Which I passed onto my sister we both have never had a problem, it's 5 years old now and still going strong, Now my camera is wiggin out and I need it to work ASAP CAN ANYONE HELP US
Jun 13, 2010 | Olympus SP-565 UZ Digital Camera
How can i email on my i9 phone if there is no
the @ is under symbols key in option (along w alot other symbols) ...make sure your mms settings are correct...when sending a regular text (if a picture is added the cell will promt you to switch to MMs mode
May 30, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I9 problem
Can anyone help me unlock my boostmobile Motorola i9 subsidy lock please?
Sep 25, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect i9 slide to unlock will not open
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
My i9 phone's slide to unlock feature wont work
THE I9 IS A JAVA BASED JAVA APP PHONE THE JAVA APP THAT RUNS THE SLIDE TO UNLOCK FEATURE HAS MALFUNCTIONED THE ONLY WAY IS TO HAVE A TOTAL FIRMWARE RESET BUT AT THE MOMENT CECT ARE NOT SUPPORTING THIS YOUR ONLY HOPE IS TO CONTACT THE SELLER OF THE PHONE AND TRY TO GET A REPLACEMENT HOPE THIS IS OF SOME HELP THERE IS A CECT FORUM IF YOU SEARCH GOOGLE
Jan 19, 2009 | Apple iPhone Smartphone
Free games for i9 phones
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
Hope that helps.
Dec 23, 2008 | Dual Electronics CECT P168 Cellular Phone
Can't take picture with monitor off?
When the LCD display is "off" the focus mode is automatically switched to "Single AF" mode (since there is no way for the user to confirm that the proper subject is focused) and unless focus is locked the camera cannot fire. When the camera is in "Continuous AF" Focus mode the camera will take a picture whenever the shutter release button is pressed, wether or not the subject is in focus. You can take a photo with the monitor off, but the camera will have to lock focus before it can fire and will not respond as quickly as with the monitor on.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
