Question about Sewing Machines
Kenmore 385 sewing machine gets stuck in reverse
The reverse button gets stuck when I use it. I am able to take the side cover off and use a screw driver to pop it back out but what can I do so that it won't keep doing this? Thanks!
    Problem Solver:
  • 12 Answers
Make sure that your machine is set to sew forward. The reverse button on your machine should have a spring loaded return. If the spring is in place, and doesn't appear stretched, try a drop (just a drop) of sewing machine oil. Please use sewing machine oil. Not WD-40, or any other household oil. If the machine hasn't been serviced in a while, or used alot recently, they knob may need to be "reminded" that its supposed to go in and out. :) After applying the oil, push the knob in and pop it back out like you have been. If nothing else is wrong, it should loosen up and move freely.
Posted on Dec 04, 2007
  • betsykf Sep 16, 2010
    I have a similar problem my montgomery ward signiture will only sew in reverse, unless I press the reverse button, then it sews forward. The problem is in the motor, because when I just turn the fly wheel towards me the feed dogs go in the right direction.. I tried switching the connectors in the motor, but nothing changed. the motor still rotates backward. any suggestions short of building a mount to hold motor away from machine in the opposite direction?
How do I oil a Kenmore 385 sewing machine
Are these the pictures you have?
KENMORE 385 12612090 Owner Manual Oiling The Machine Oil The Underside
Something you can do is slightly wiggle the handwheel (do not turn it in reverse). The handwheel should always turn toward you.
Look at the pictures and watch where metal rubs on metal that might match the picture and apply one drop of fresh, good quality sewing machine oil.
Aug 04, 2016 | Kenmore Sewing Machines
How do I fix my kenmore sewing machine. Model # 385. 1960180
Consult your manual, the Troubleshooting section. It should explain what the Code 5P means and how to correct it.
Aug 11, 2015 | Kenmore Sewing Machines
385 kenmore sewing machine
385 just means it's a Janome badged for Sears. The actual model number is the first 4 or 5 digits after the 385 portion.. like 385.1234567890
Machines that don't reverse are often dirty or the lubricants are gummed up (try running the machine in 15 minute bursts, full throttle, with the needle out; sometimes that helps.) Otherwise:
Mar 23, 2014 | Singer 3116 Simple
Reverse not working
it would be a good idea to have the machine checked to see
if the reverse button is damaged or broken
Jun 11, 2012 | Kenmore Sewing Machines
My sewing machine is sewing in reverse Kenmore 385-1960180
Hopefully this is only a mechanical problem that can be fixed with oil. If not it is either a stepper motor or circuit board. If you are not comfortable with removing covers and oiling then it needs to go to the shop.
Jan 20, 2009 | Janome 2049LX Mechanical Sewing Machine
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Oct 26, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
1,474 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
