Question about HP LaserJet 3050 All-In-One Printer
How to copy legal size paper - HP LaserJet 3050 All-In-One Printer
  • 110 Answers
Go to file menu and page click on page setup then click on paper now you select the letter size, A4 size, or Legal Size etc.
Posted on Jul 31, 2009
I am not print lagiel siz
Posted on Aug 25, 2010
3 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: How do I copy a legal size document?
You need to change it in the menu, it's stopping because once it reaches the letter size the sensor detects that there is still paper there and jams.
Posted on Oct 23, 2007
SOURCE: sending and receiving fax on legal size paper on
What's the question? You can send a fax on legal size exactly as you do with lettersize. As for printing, you only have 1 size of paper available at a time (1 paper source) , so put legal in it if you want.
Posted on Apr 13, 2009
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
I cant copy legal size
Be sure to set Paper Size to LGL (14 inches long)/FLSP (13 inches long).
Additional Function > Common Settings > Reg Paper Size > Drawer 1 > Select right paper size
Jan 25, 2010 | Canon imageRUNNER 1023iF Black and White...
Coping Copies of Legal Size
For either a Printer or Copier, the 1st thing is you have to use full-size LEGAL paper. If your copier won't accept this, then you cannot do it. It has to fit in the paper tray.
Second, use the setup menu of your copier and set paper to 8.5 by 14 or LEGAL size, for a Printer
goto Start, Settings, Printers and Networks and find your printer/copier, Right click it, select Properties, select General or Paper tab and look for Advanced Settings. There you will find Paper Size pull down. Change it to Legal, Click Apply, Click Close
Done!
Mar 26, 2009 | Office Equipment & Supplies
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
Making copies onto legal paper
Press the paper select key for 3 secs.,a default paper size will be shown ,press the zoom keys + or - untill F12 is shown , press the recall %/enter key ,press the zoom keys again untill the correct size is shown , Lg should should be shown for legal,press the recall%/enter key again , the selection should flash and the copier will return to the ready state.
Jan 15, 2008 | Copystar CS-1500 Copier
Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
HP LaserJet 3050 All-In-One Printer Logo
490 people viewed this question
Seeker5211
Seeker5211
