Typically the compatible heater models are all labaled, different sizes, on the data plate of the air handler.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: Rheem Air Handler will not run
We tried to bypass at the Tstat. Thanks for your time and interest.
SOURCE: Blower out of alignment
SOMETIMES DUST WILL BUILD UP ON THE SQUIRREL CAGE ON THE BLOWER THAT WILL PUT IT OUT OF BALANCE THE OTHER THING IS TO SLIDE IT OUT AND FIND OUT WHERE IT IS HITTING IT DOESNT TAKE MUCH TO FORCE IT BACK
SOURCE: unit stopped working condenser & air handler
Your question is very vauge. If you are "absolutely" sure breakers "in all locations" are fine, then I will give you the troubleshooters way to find problem. BE AWARE, SOME OF THESE SUGGESTIONS REQUIRE KNOWELEDGE OF ELECTRICAL CIRCUITRY. UNQUALIFIED PERSONS SHOULD NOT ATTEMPT.
Before getting technical, if you have a digital thermostat, it may be that you have one that requires batteries. replace these.
1. if nothing runs and breakers (high voltage) are ok, then you most likely do not have 24V control voltage or 24V switching. This leaves us to look at transformer in air handler or thermostat problem. The transformer in your air handler is usually where all your control power come from unless you have a battery powered Thermostat.
2. if you hear a "very faint" hum in your air handler or furnace, it is most likely your 24V transformer is OK. If you do not hear a hum, there may be a power problem. This could be bad transformer, bad fuse for transformer, or no power to transformer, or simply a good quiet properly operating transformer. An electrical meter is really only way to tell.
Any further checking would require a professional.
SOURCE: I have a Rheem Model
We can get you the wiring diagrams for your Rheem model. Not sure how to attach a PDF to this area, but if you contacted us either by phone or e-mail, we can send it to you via e-mail. You can contact ComfortGurus.com at 866-519-2461 or visit our site and use the "contact us" page to send us an e-mail. We are a full-line Rheem distributor for parts and accessories if you need any parts in the future too. Let us know if we can help.
