Question about Karcher 1750 psi Electric Pressure Washer
I got the pressure washer started - lots of smoke etc after not having used 3 years. I then poured in wrong oil to top it off - my brother's chain saw bar oil. DARN. After 3-4 minutes it started rattling and stopped. Can't pull the chord to get started. Did it seize the engine? I have drained all oil. Can I try using a cleaner, light weight oil to try to unlock it?
    Brigadier General:
  • 4,090 Answers
Nope! you have blown the seals and most likely the cylinder is full of water. You will need to take it to the repairer to have it cleaned checked and new seals fitted. $200
Posted on Jul 31, 2009
Why do I have blue/white smoke coming out of my exhaust?
Appears you are burning oil intermittently. Ring job in order.
Oct 10, 2015 | Honda XR 650 L Motorcycles
3.5 timing chain noise one sec on cold start
Oil pressure pushes the tensioner foot up against the chain. When the rubber face wears down it will come to the end of it's travel and then stop. High mile engines don't produce a lot of pressure on a cold start, so look at the pressure regulator in the oil pump and replace the timing chain tensioner.
Sep 07, 2014 | Cars & Trucks
93 honda accord, replaced head gasket but smokes bad in morning from the exhaust
The valve guides in the cylinder head are probably worn, allowing oil to seep into the cylinders overnight and burn off when you start up in the morning. That is why you're loosing oil, it's being burned off.
Aug 22, 2012 | 1993 Honda Accord
My Ryobi petrol RCS 3540c chainsaw, smokes badly and won't cut into the wood, it just slides off the top most of the time.
Check that the chain is on the right way around. The cutting edge of the teeth on the chain, at the bottom of the bar should face towards you and away from you on the top. It's most likely that the chain is facing the wrong way. If you don't know how to fit a chain look at the video on http://www.ehow.co.uk/video_4419336_replace-chainsaw-chain.htm
If that's not the problem then the chain is blunt and needs to be sharpened badly. You can sharpen it, with a special file which can be got from chainsaw dealers, or take it to a garden tool hire centre and have it sharpened professionally. It has to be sharpened professionally from time to time anyway to keep it cutting straight so if it's that blunt I'd recommend you get done professionally now.
The smoke if it's coming from the chain is caused by overheating from trying to cut with the chain which is too blunt or turned the wrong way. If the smoke is coming from the engine check your fuel. You should have petrol mixed with 2 stroke oil. The saw manual will give the ratio of 2 stroke oil to petrol. If you use too much oil or if it's not 2 stroke it will cause smoke from the engine. Also if you use cheap oil it can cause smoke. It's best to use good quality oil like husqvarna or stihl 2 stroke. These also protect the saw better than the cheap brands you get at car service stations which are really only meant for boats which are water cooled.
Jan 20, 2011 | Ryobi Garden
Chainsaw is smoking excessively when in use
White smoke is usually associated with burning antifreeze in an automobile engine, but in this case, trying to cut wet wood might be suspect. The chain must be properly sharpened and the teeth cut toward you on the bottom run of chain. When the chain is properly adjusted, it should not droop from the lower edge of the bar, but no so tight that you can't turn it by hand. Forcing a poor cutting chain into the kerf will overheat the chain and cause it to become loose quickly. Hope this helps!
May 29, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
New GSX-R Owner...questions
short pipe shouldn't cause you any problem...if it starts to backfire a lot after coming down from high speeds then you might want to think about installing something with a little more back pressure. #2 you"ll know it needs an oil change by if it smells burnt, has a slight fuel smell, or it looks real dark black. Now never ever top off your engine oil, pour only 2 and 1/2 bottles at first, start engine let oil get into the filter now shut off, pour a little more in, fill up to 3/4 either on site glass or using a dip stick, and if it uses a dip stick dont screw it in, just drop it in to measure. also check the chain for wear and stretch....you"ll know its stretched buy purchasing a pit bull type rear wheel stand which is a must..you'll always be using it...and spin the tire and check several spots on the bottom of the chain...if some portions are tighter than others then its been streched and now your riding on borrowed time. I"ve had three chains on my bike in a year and a half. Now im gonna need some sprockets next. #3 try to push start the bike to get it started then if it does start ride it somewhere where you can run it for a good solid 15-20 minutes to charge up the battery. if thats all it was, then your battery is probably old and will need replacing..avg bat life is two years! batteries can be expensive, i bought a Yuasa $95 about a year ago and working fine.Hope you found all this info very helpful.
Apr 06, 2010 | 1999 Suzuki GSX-R 750 X
Smoke is billowing out of engine - I added oil to the engine and when I press hand nossle white smoke billows out front of engine
sounds like the engine is overfull.drain all oil oil & start again you may have a lot of petrol in the oil.
Aug 22, 2009 | Garden
Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Jun 03, 2009 | Karcher 2500 PSI Pressure Washer
3.3L engine jumped timing
sound like compression ring gone pressure goes in oil if noise i dont think it worth to fix that motor a good second hand one there gone engine normally hope it FIXYA our problem thanks pierre
Jul 04, 2008 | 1999 Dodge Grand Caravan
Karcher 1750 psi Electric Pressure Washer Logo
201 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
