Question about Samsung L100 Digital Camera
Screen not working
When i press the power on button it comes on but the screen dosent come on its completly blank and the zoom is working and so does the blue and green lights how much willthis repair be
    Brigadier General:
  • 4,090 Answers
Probably more than the camera is worth LCD screens are expensive
Posted on Jul 31, 2009
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
Can't unmagnify iphone
Double tap using 3 fingers to unmagnify from zoom.
If this doesn't work, Use 3 fingers to move the screen. Go to settings/general/accessibility and turn zoom off.
Oct 03, 2009 | Apple iPhone 3G
My laptop comes on but the screen stays blank??
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
Good luck
~Phil
Jan 09, 2009 | Computers & Internet
Computer dosent turn on..screen is blank with blinking LED
have u tryed
unplug all of your plugs at the back like blow on them like i do to get lil partcals of dust out then plug all back in and mite work or maybee ur power cord is screwed a bit and u mite have to get a new one whats happednd to ur comp happend exactly the same with mine and i screwed with myn for ages and it finaly worked so maybee just try all that n then if that dosent work as drliativ hes a good guy and will help
hes helped me out a few times hes a great guy
Dec 02, 2008 | Smart Modular SV3170A
Need to set the date and can't find manual--
Try this:
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
How do you set the time on the Canon sure shot 80u
Sep 10, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
Samsung L100 Digital Camera Logo
207 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
