Question about LG Vu Cellular Phone
Error fatal file: fs_device.c line: 110 unexpected device read fail ure. page=66048
What is fatal error 762
Trying to test this plugin on XAMPP localhost test site. Nothing shows up so I looked for errors and found this: Warning: require_once(C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow): failed to open stream: Permission denied in C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow\blip.php on line 762 Fatal error: require_once(): Failed opening required 'C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow' (include_path='.;C:\Program Files (x86)\xampplite\php\PEAR') in C:\Data\xampplite\htdocs\zinnia\wp\wp-content\plugins\blip-slideshow\blip.php on line 762 --------------- The code on line 762 is the require_once, but here's a few lines before // attempt to talk to WordPress $blog_header_path = preg_replace("/wp-content\/.*/", "wp-blog-header.php", getcwd()); if (file_exists($blog_header_path)) { require_once($blog_header_path); }
Feb 12, 2015 | Office Equipment & Supplies
Tip
STOP: c000021a {Fatal System Error}
This article is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact Technical Support.
When you use a server or a workstation that is running one of the operating systems that is listed in the "Applies to" section, you may receive the following error message: STOP: c000021a {Fatal System Error}
The Windows Logon Process system process terminated unexpectedly with a status of 0xc0000034 (0x00000000 0x0000000)
The system has been shutdown. Note The parameters in parentheses are specific to your computer configuration and may be different for each occurrence.
CAUSE:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Resolution will not fit here so kindly go to:
http://support.microsoft.com/default.aspx?scid=kb;en-us;156669
I hope it helped you. Rate for this information will greatly be appreciated. Thank you!
on Jan 20, 2011 | Computers & Internet
Fatal error: Couldn't get device caps DirectX error message: D3DERR_NOTAVAILABLE File: \project\igi2\B\2\PC\pc_direct3d.c line: 2634
did you install direct x in your computer? if not then download it and get it installed and then try reinstalling the program
Apr 07, 2012 | Microsoft Windows XP Professional With...
Avg installation fatal error 0XC0070643 fATAL ERROR URING INSTALLATION MSI engine: failed to install the product
0XC0070643
Oct 19, 2010 | Computers & Internet
I have blue screen saying error fatal file:fs_device.c line: 110 Unexpected device read failure, page=91077
Here are some common causes of blue screen,
Also provides you sulotions of Blue Screen fix.
Click here to fix Blue Screen.
Feb 19, 2010 | LG Vu CU920 Cellular Phone
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Enteri am having a big problem with my acer 5315 laptop it keeps coming up with a blank black screen and at the start screen after logo it says windows failed to start. a recent hardware or software change...
I might advise you reformat the operating system of the computer, or check the peripheral devices for this computer if properly connected? You got a fatal error it means that there is something that is not reading by the memory of the computer.
Mar 16, 2009 | Computers & Internet
LG Trax cell phone
You must of gotten the ROM bootloader chip wet. You can buy a cheap GoPhone from AT&T and put the SIM card from the LG into the new one and you will have your contacts on the new phone.
Apr 17, 2008 | LG CU500 Cellular Phone
Syntax error
go to this site and look under "error codes"
go to computer and system error codes
http://checkitright.spruz.net//main.asp?page=dp&dis=834222
Feb 07, 2008 | Computers & Internet
LG Vu  Cellular Phone Logo
152 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
