Question about Emprex LM2201 22" LCD Monitor
My laptop froze one time and i had to hold the power button to shut it down. when i turned my laptop back on which is plugged with the emprex, the emprex LCD monitor went to auto adjustment by itself and now its too bright. how do i change it back to normal?
  • 398 Answers
Try to do a syestem restore on it. click on start go to programs. then accessories system tools and at last system restore. and go back to the last time it worked ok.
good to you sawdust46
Posted on Jul 31, 2009
My grandson just got his nabi and it is froze up have tried letting the battery run out and turning it off and on wont even shut off can you please help
Try this
Plug in the charger
Hold down Volume + and Power buttons at the same time for at least 15 seconds. Remove the charging cable from the tablet, then plug it back in.
Sep 27, 2017 | Tablets & eReaders
LAPTOP FROZE ONLINE. HAD TO SHUT DOWN MANUALLY AND NOW WILL NOT TURN BACK ON. BLUE POWER LED COMES ON THEN SHUTS OFF. THERE IS A SOUND AT THE DVD DRIVE AS IF IT IS TRYING TO LOAD A DISC BUT THERE IS NO...
ok first remove ac adapter , remove battery ,, and press and hold the power button for 25-30 secs..plug in the ac adapetr after that (not battery) and power on..if it does not power on then it could be the system board faulty, replace system board.
Apr 13, 2011 | Gateway NV7915u PC Notebook
My Toshiba A215-S4697 froze and I shut it off by holding the power button down. When I went to turn it back on the power light came on but the Satelitte light didn't. The screen wasn't on either and the...
it could have failed,but its more likely you have sequential procedures for the power button,like holding it down for more than 5 seconds etc--you might have just put your machine into "standby mode"--check manufacturers site for power key process--good luck!
Davey snake!
Oct 17, 2010 | Toshiba Satellite A215-S4697 Notebook PC
Computer froze, I tried to restart but it would not shut down. It is now stuck with only background showing. Can you help.
Press and hold the power button for about 10 seconds will power off the MacBook Pro.
You can then try turning it on again normally.
If the problem with freezing reoccurs on start up, then hold down the power button again, and turn it off. Unplug the MagSafe Power Adaptor from the MacBook and the Wall for several seconds. If the battery is removable, then remove it, wait for a few seconds and re-insert it. Plug the MacSafe back in if desired. You should now be able to start up the MacBook with no problems.
Sep 08, 2010 | Apple MacBook Pro Notebook
My Toshiba A215 is frozen. The power button does not turn off. Cntrl/alt/del does nothing Mouse and claock are frozen as well. How do I fix? I was trying to download video files to ext hard drive. Window...
hello, press down on power button and hold it for about 10-15 seconds and it should shut-off, wait for about 5 seconds before turning it back on. If for some reason holding down power button doesn't shut it off, then simple unplug the power from the laptop and then flip the laptop upside down and locate the battery eject lever(little slider switch to kick out the battery) slide it to the unlock position and remove battery. Once again wait for about 5 seconds and plug the battery back in and then the power adapter and power on your laptop.
Tip: try copying few files at a time to get a better success rate and avoid any failures.
I hope this helps.
Regards & happy holidays.
Amar Sondhi
Dec 24, 2009 | Toshiba Satellite A215-S5822 Laptop
Phone shut off
Have you tried removing and replacing the battery pack? Or removing the battery and plugging it in to the charger? If neither works, try holding down the Power button to get it to start back up.
Jan 06, 2009 | T-Mobile Wing™ Smartphone
Iphone froze
hold down the power button and home button for roughly 10 seconds sometimes it can take anything up to a 1minute. This almost always works. My froze and i tried this, worked first time.
When your screen goes off from holding them down. Plug you iphone into itunes and it will load and your all set.
Oct 07, 2008 | Apple iPhone 3G
Emprex me1 media player firmware update
Unplug your Emprex with the USB plugged into it, then while holding down the power button plug the emprex back in, keep holding the power button down until the screen changes from loading to the updating page, usually you have to hold the power button down for a around 15 seconds then the update starts, once it starts updating let go off the power buton and let it do its thing
Aug 11, 2008 | Televison & Video
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
Frozen screen
All you reaaly have to do is let the battery run out. Then once the mp3 is dead, charge it. The screen should be unfrozen.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
Emprex LM2201 22" LCD Monitor Logo
83 people viewed this question
Top Emprex Computers & Internet Experts
David Payne
David Payne
Are you an Emprex Computer and Internet Expert? Answer questions, earn points and help others
