Question about Whirlpool Dryers
Whirpool dryer 6 year old heat only few minutes and then burner turn off by itself but dryer keep runing without heat. this is a gas dryer. can u help me which part i need to change? thanks
  • Whirlpool Master
  • 4,655 Answers
This is most likely to be the 2 coils on the gas valve. When the coils weaken over a period of time they tend to allow the gas come on for a few moments and then the gas valve shut ending the flame.
The part number is 5303931775 and by clicking the part number it will take you to where you can find the set.
Let me know if I can help if you run into more problems and I will help get your dryer going, Thanks Sea Breeze
Posted on Jul 31, 2009
  • John Tripp
    John Tripp Jul 31, 2009
    Here is where the coils are located. Your dryer is gas and has no element. It does have an igniter but because yours is gas it will light and the igniter is good.
  • John Tripp
    Thank You Very much for your Rate! Again if for any reason you need my assistance you may contact me at appliandepartsse@yahoo.com Thanks, Sea Breeze
  • 98 Answers
Where do you live? Sounds like you need a new element
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Kenmore Dryers
When I turn on the dryer, it takes a few minutes before the burner ignites, and will only heat for about 5 minutes then the burner shuts down.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 02, 2010 | Whirlpool Dryers
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Speed Queen dryer does not heat...
you have weak gas valkve coils and they will work when cold but after a few cycles they become electrically open and will not allow the gas to flow.
just replace both gas valve coils and that will fix your problem.
Dec 29, 2008 | Speed Queen AES68AWF Gas Dryers
Gas dryer fires up once and that's it
suspect coils on burner once burner fires and heats up area coil may fail on next firing 2 coils are present.. whirpool sends both in kit
Apr 26, 2008 | Whirlpool GGX9868J Gas Dryer
Dryers Logo
93 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
