My tv fail down and now the sceen is broken and all the image is gone how can I repare it? it's a 2005 model LCD TV Model: LC-15Y3D INPUT: ~ 100-240V 50/60Hz 48W
    Brigadier General:
  • 4,090 Answers
Miht be cheaper to buy a new one! you could try an insurance claim but they might suggest to replace it rather than repair it if it exceeds 40% of the value of a new one
Posted on Jul 31, 2009
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
I have a harwa 32" LCD tv model LC-32W5S with a broken screen. Do you know any suppliers for a tv screen for that model.
With the price of LCD tv's being so inexpensive now days, is it worth replacing the screen..? Not sure where you live but in my area they are always on sale for approx. $140 us
Jan 28, 2015 | Televison & Video
No Image on sharp LC-26A37M TV 32" AQUOS
two common problem if there a sound lcd panel are broken if totally deadset power supply first to replce
Mar 12, 2014 | Sharp lc-26a37m Multisystem TV For 110-220...
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
When I turn on my TV sharp model LC-32D44U turn on a 2 second on analog canal 2 than turn off and start a green led flashing ..
common problem for this particular model, one or more CCFL (backlight lams) falure. Lamps are not avalable as the replacement parts, only way to get them is to take appart bad/broken screen tv.
Oct 12, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Brand new TV, spotty HDMI functionality (sometimes recognizes cable box or comupter, but not always). Attempted firmware update on a Sharp Aquos LC-32SH7E (European model). Don't think it ever...
Did you go through the entire factory reset? When you plugged in the power cord did you continue to hold the volume - and input button until the television powered on and a K appeared on the screen never releasing at all?
Force the tv on by holding down channel down and volume + on the tv while plugging the tv in. See if the tv still lights up and if you get audio.
Jul 28, 2010 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
My tv won't recognize that my laptop is connected to it, what do i do?
After connecting the VGA cable, make sure you select the correct input from the TV's input selection. Once you have selected it, hold down the Function key "FN" located on the lower left of your keyboard, and also press the F key on the top row which will say lcd or a picture of a monitor on it. Usually F5, F7 or F8. This tells the computer you just added an additional monitor to it. Doing this once sends the image to the TV. Twice will remove image from laptop and only display on the TV. A third time restores image to PC and nothing on the TV. Let us know this worked. ;o)
Jul 01, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
No picture
If model of your TV is LC19SB25U, TV powers up, TV has back light,but on picture or menu, The problem is the part called main unit.
Oct 14, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
LCD TV Screen repair
I have a Sharp LC52XD1E TV , It has a crack on the screen needs a new screen can it be fixed and is it worth the repair?
Feb 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
