Just installed and No Spin light comes on
I have just installed this GE WSSH300GWW and it starts for two seconds. The No Spin light comes on and it will not do anything else. The hoses are fine, Everything seems to be in order for operation.
  • pipalfarms Jul 31, 2009
    It is a front loader, but thank you. It seems to be locking okay as well.
Pipalfarms i have the same problem with mine did you ever find a fix???
Posted on Aug 02, 2009
    Brigadier General:
  • 4,090 Answers
Check the lid is closed properly
Posted on Jul 31, 2009
I have a ge WSSH300GWW front load washer. All of the lights light up, blink 3 times on the panel and the machine beeps 3 times. What could be causing this problem and is it something I can fix myself?
I would check the pump is free to turn and the filter is not blocked, then check water comes in when the solenoid switches on. Is the drum free to move or has the belt broken.
Jan 20, 2017 | GE Washing Machines
I TOOK THE 2 SCREWS OFF OF THE DOOR LOCK, THINKING I WAS REMOVING THE FRONT PANEL OF MY GE WSSH300GWW
First unplug the machine. If you remove the bottom panel you can reach all the way to the door lock position and should be able to reattach it easily. Why if i may ask were you trying to remove the panel?
Jan 27, 2013 | General Electric WSSH300GWW 3.5 Cu. Ft....
GE front load waher Model #: WSSH300GWW fills and agitates, but does not spin and drain.
take drain hose and lay it in a bucket to drain water or a wet vac works better. remove 2 scews from lower pannel it will drop down and come off. look for a accordian shaped black hose. disconnect it and remove junk in it. check inside the pump inlet for stuff it's the thing one end of the funny hose is hooked to. put back together and don't over tighten clamps nut driver tight is fine.
Feb 17, 2010 | GE Washing Machines
Bra wire stuck inside washer between drums - WSSH300GWW
If you are unable to remove the wires from inside using needle nose pliers, then my advise is to call in a professional. Taking out the inner tub on a front load machine is involved, and you open yourself up to several potential leaks as well as bearing damage.
May 04, 2009 | Washing Machines
GE front load washer WSSH300GWW moves in spin cycle
the machine is off level. open up your installation guide, and it will provide instructions on how to properly level the machine.
if you have any questions, feel free to email me at thadoggma420@hotmail.com
Jan 22, 2009 | General Electric WSSH300G Front Load...
CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
May 23, 2008 | GE WSXH208A Front Load Washer
My Ge wssh300gww will
It is probably a clogged pump (don't look in owners manual for info - curiously it isn't in there - just says call tech - bolocks!)
Remove 2 screw on front bottom panel.
Remove cover.
Plastic boot and pump are on right had side. Clean out - and use the change to buy a drink - celebrating the fact you didn't have to spend hundreds on a tech!
Mar 07, 2008 | Washing Machines
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
