Question about Maytag Bravos MTW6600T Top Load Washer
I have a maytag heavy duty stack washer dryer. tonight The washer stopped working. The elctronic panel seems to be working and the water filled but the machine would not aggitate, spin etc.. it did show a 1E (or IE) warning light. Any ideas?
  • 98 Answers
Possibly the timer needs to be replaced, if a few of the teeth on the disc get broken off, it will not turn, and that causes it to NOT go into the next cycle. Happened to me, thank God for warranties
Posted on Jul 31, 2009
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
Maytag stacked washer/dryer fills with water, makes noise like it's working, but won't agitate, but at the end of it's cycle pumps out but won't spin either. Is this a belt problem? If so how hard is it to...
Definately sounds like the belt is off. Not too big of a problem for small hands mechanics. Usual problem lately with Maytag is the spindle pulley. For some reason they haven't been tightened properly and the pulley and belts are falling off. Pull it out from the wall remove the panel and see what you've got, really simple on the bottom end. Complicated stuff is up in the control panel. Make sure you get the pulleys lined up as close to level as you can or the belt will jump off on you during spin cycles. Good Luck!
May 10, 2009 | Maytag LSE7806A Top Load Stacked...
Replace wax motor on neptune stacked w/d
I just recently purchased a used Maytag MLE2000AYW Stacked washer/dryer. The problem I am having is that the washer unit seems to turn on, the lights go on, fills with water, but doesn't not engage in the wash or spin cylce. There also seem to be a kind of intermittent spinning sound every five seconds or so when it is in the wash cylcle. Can anybody give me some ideas to troubleshoot for?
Mar 31, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
20 year old maytag stack, washer doesn't stop agitating
Your control board is bad. It must be replaced. It can not be repaired.
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Water leak from washer
The element is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag Bravos MTW6600T Top Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
