Question about Refrigerators
Refrigeratr is not cold and has room temp. deep side has snow.
  • 528 Answers
Is the compressor working? Can your here the normal sound? In that case, the refrigerator needs an gas refill.
Posted on Jul 31, 2009
I have a centrex air con.. and i dont know what to do the air is not cool.. and there no button in the remote that i could use and fix it..
In your remote, there is mode button, the symbols for each option will display. The symbols are:
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.To get proper cold air set temp 23 degree and mode"cool". To get heat set temp minimum 3 degree more than room temp and mode in "Heat"
Feb 02, 2011 | Heating & Cooling
I have lost my manual for my bio tech plus air con. my air doesnt seem to be cold at all, not sure if i have right setting, on the remote there is a sun, snowflake auto and i think a raindrop, which should...
Dear friend, find below symbols for mode setting. For cool keep minimum 3 degree less than room temp and heat keep minimum 3 degree higher than room temp. Dry mode will help you only in wintertime. Thanks.
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Feb 01, 2011 | Heating & Cooling
How long should it take for a 18 cu ft. chest type deep freeze to get cold?
From room temperature if just plugged in rule of thumb is 24hrs to properly reach temp. Place a glass half full of water in shelf when is frozen solid the unit should be plenty cold enough to keep food. It is always a good idea to get a small fridge thermometer to make sure of temp.
Oct 26, 2010 | Whirlpool Freezers
Ice buildup in wall mounted unit
Icing on evaporator is caused by:
Dirty evaporator
Bad cold control
Low charge
Low ambient air temp
May 25, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Fridge at room temp
Good day,
two common reasons fro this.
1. The fan motor in the freezer compartment has failed and is not driving air to the fresh food compartment.
2. The second common problem is the defrost system has failed, blocking air from entering the fresh food compartment.
First indication is frost building up on the rear panel in the freezer. Remove rear panel and inspect.
Here is an excellent tutorial on defrost system repair.
http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 04, 2009 | Whirlpool Refrigerators
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
Fridge side cant keep 100 percent cold
Have you noticed a big difference lately in the cooling of the cold food section? Any time you open doors to a refrigerator or freezer you allow them to exchange room temperatures with inside ambient temperatures. The only time you should be concerned is when these temperatures begin to remain abnormally high. Many times the temperature rises in the kitchen while diner is prepared. Those temperatures also affect how long your refrigerator need to run to maintain the temperature settings you select. Your refrigerator has something called an Adaptive Defrost Control. If you should have problems with it you would notice a big difference.Another thing that can help is to make sure the condenser coils below refrigerator remain clean and clear of dust. The warm air circulating below your refrigerator is as important as the cold air inside. As for the vents that lead from freezer to cold food section they sometime become obstructed especially if they have a damper inside and frost locks the damper shut. If I missed something here please let me know, Thank You, Sea Breeze
May 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint hss25gp Not keeping cold or freezing
Check and clean the condenser coils where heat is transfered to the room air. If they are plugged with dust it will cause your problem. Check the back wall of the freezer for snow. If snow is on the back wall you have a defrost system problem.
Mar 09, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
