Question about Premier Heating & Cooling
FAU unit is running, but does not kick-on air-conditioning unit. Units are 10 years old.
    Problem Solver:
  • 5 Answers
Let's try the simple stuff first. breaker to outside unit,see if you have a float in your drain pan under the inside unit and if your drain pan is full, check that the thermstat is set correctly, other possible causes low r22, the wire coming out of the house and to the outside unit had been cut.. hope this helps.
Posted on Jul 31, 2009
Air condition system is no longer working and the person who checked it out says it needs a new system installed
get a second opinion when this statement is made
ac units only need replacing if parts are no longer available for repairs or the quoted repairs make it uneconomical to repair when compared to new units
for example
if your units is 15 years old, parts will be scarce and if it needs a compressor the cost of the part and labor will be close to the price of a new unit
new units are inverter units and are less costly to run and the larger units have reverse heating capability which makes them a heater unit in winter
best advice -- get a second opinion and then quotes for new units and make a decision on that information
Jan 22, 2017 | Cars & Trucks
Tip
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central air conditioning unit. They also are a very good alternative to window air conditioning units. I will explore the use of these units more closely and look at how they can be used effectively.
One of the many problems encountered by the professional is when they are asked to install central air conditioning in an older home that was never designed with air conditioning as even a possibility. The walls may be very thick stone. Often they have very little or no insulation. The floor structures may be rough cut lumber. The joists spacing may be random. Walls and ceilings are plaster and lathe. Basically everything is stacked against any type of ducted central air conditioning. Many log style homes also are not very easy to get any kind of ducted central air conditioning installed. The open ceilings and the bare log wall design does not allow for any kind of ducting. I'm sure there are other situations. These are the ones that I have come across most frequently.
If you have a home or building that falls into one of these categories you may want to investigate installing a ductless air conditioner. This type of air conditioner can be installed in almost any home or building. The small indoor unit can be attached to the wall with a few screws. Most of the units only require that a three inch hole be bored through the outside wall. In new installations the units can be placed on inside walls with some fore thought and planning. For installation in older homes or homes that are already built you will want to plan the units to be on the outside walls.
The outdoor condenser units can be placed up to one hundred feet away from the indoor units. One outdoor unit can be used for many indoor units. Up to four indoor units can be attached to the same outdoor condenser. Some very advanced electronics will control the operation of the condenser and compressor to supply the refrigerant to the indoor air handler units that are running at the time. With variable speed technology the compressor and the condenser fan will only run as fast as needed. This technology has become very efficient in the last few years. You do not have to give up any efficiency with these ductless split units.
Another advantage to these mini split air conditioners is that they can be controlled to run only in the rooms that you actually need air conditioning in. If you are not going to be in a room you can shut down the unit. The units also have timers that can be set to turn the air conditioning on or off at preset times. If you are not going to be home all day the air conditioning can be setback or turned off. The timer will turn on the air conditioning so that you return to a cool house. Central air conditioning is very hard to zone effectively. Also with large central air conditioning systems the outdoor compressor will be running at full capacity even though only a few rooms amy be calling for cooling. There are some central air conditioning systems that are do some staging and variable speed technology. These are not as efficient or as effective as the ductless split technology.
Ductless split heatpumps are another great idea to look at. For a few dollars more you can also very easily have heat from your air conditioning mini split. Then especially in the mild spring and fall weather you can have some very efficient heat with out starting up that big monster of a furnace or boiler in the basement. In southern climates the heatpump version of the ductless split system may provide enough heat year around.
Ductless split air conditioning is definitely something that can solve many problems for some homeowners. Add to that the many advantages of these units and you will find that they are worth every penny that you will invest into them. As with any project like this make sure that you screen your contractor. These units are not for do it yourself people. There are many things that need to be done correctly for these units to work properly and efficiently. A refrigeration license is also required to install these air conditioners.
By doing a little research and hiring the right person you will enjoy many years of trouble free service from your new ductless mini split system.
on Dec 04, 2009 | Heating & Cooling
How do I make smoke alram stop going off when there is no smoke or fire.
If it does not have a battery backup there is a good chance it is over 20 years old and needs to be replaced.
Feb 21, 2015 | Home
My 9 year old Honeywell T8001C has no display. My FAU AC power breaker is not tripped. I tried a new Honeywell RTH2510B and a RTH7500D but the Fan does not come on with either of the new units after...
This is why battery powered tstats are misleading. The battery provides the power to the tstat but your unit is not providing low voltage in order to run. Air conditioners are controlled by relays and contactors. This means your unit constantly has high voltage going to it but each component runs through a relay in order to turn on. These relays are energized by the low voltage that runs through your tstat. Your tstat is not getting this low voltage. Either your float switch on your drain line is tripped, your blade style fuse is blown on the secondary side of the transformer or your transformer is bad.
Aug 08, 2017 | Honeywell Heating & Cooling
Dehumidifer Runs but doesn't collect water
Depends on he conditions of the water. These units are relatively inexpensive and typically do not justify the expense of repair. I'ld donate it to an air conditioning school and buy another one.
Jul 18, 2010 | Whirlpool AD40USR Dehumidifier
I turn it on (montana 5th wheel) and it sounds like it's tryin to kick in the compresor that is and the fan comes on and the compressor tries to kick in about every 30 seconds but cannot?? it's about 4...
The compressor is trying to start and cannot because it is broken inside and will need to be replaced. The compressor can be replaced by most anyone that is familiar with working on home central air conditioning units. I have replaced a few compressors for units like yours. Have a professional check it out. It could just be the start capacitor, but usually it is not.
Nov 15, 2009 | Dometic Rooftop RV Air Conditioner
I have a Totaline thermostat for my upstairs and downstairs. I have the thermostat in the OFF position but it keeps kicking the fan on. The green LED light is not lit up showing me that it is even on. What...
First make sure the thermostat fan switch is on "auto" and not set to "on". Also some thermostats have the ability to run the fan intermittently for air circulation in the house using the FAU filter to keep the inside air clean. So check your manual for the thermostat and see if it has this capability & how to turn it off if it does. Otherwise it could be a malfunctioning thermostat or FAU.
Oct 29, 2009 | Heating & Cooling
Heating & Cooling Logo
69 people viewed this question
Top Premier Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Premier Heating and Cooling Expert? Answer questions, earn points and help others
