Question about LG WM1812C Front Load Washer
Drum bearings replacement
We require a manual on how to replace the drums bearings on our washing machine. The make is LG WD80130F front loader
  • Anonymous Mar 27, 2014
    front loader drum does not spin
  • 98 Answers
Go to this site...
www.Howthingswork.com
it is amazing what you can find there
Posted on Jul 31, 2009
Replacing drum bearing on a ZANUSSI FJS 874 front loader ?
This is not a simple job, it can be fine but requires the complete disassembly of the machine to change the bearings, there are 2 bearings and a seal that require replacement, I can assist in guiding if you wish to do so, it takes around 3 hours total to strip and rebuild.
Jun 16, 2016 | Zanussi Washing Machines
I have a LG front loader WD-1049C it's 6 yrs old And has just started to make a loud noise while in spin cycle All other cycles are fine
If the washer is making a loud noise the tub bearing might need to be replaced. This is a very involved repair and will require disassembling most of the washer. The manufacturer recommends that if possible the complete outer tub and bearing be replaced rather than attempting to replace just the bearing in the tub. If the bearing is bad the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine
Feb 19, 2015 | LG Washing Machines
Washing machine vibration
I had same problem. It was actually wearing out the rubber gasket on front door. It ended up being the spider on back of drum. They corrode pretty good with the front loaders.
Mar 28, 2014 | LG WM1814CW Front Load Washer
How do you change drum bearing on lg wm-1290fhb washing machine
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
Apr 05, 2010 | LG WM-1290FHB Front Load Washer
Makes helluva noise when going into final spindry cycle
I would check the large pulley on the back for wooblyness(is that a word..lol) if so replace pulley.:)
Jun 13, 2009 | LG WD-16115FD Front Load Washer
HOW DO I REMOVE THE BEARINGS OF THE REAR OF THE DRUM FROM A LG FRONT LOADER
You can't since these bearings are pressed in at the factory and are not serviceable. You would need to replace the tub's rear shell assembly.
Feb 19, 2009 | LG WM2277H Front Load Washer
LG/ westinghouse lifestyle font loader
what you will need to do is wright down the model number and go to ebay and put in bearings for a lg then put your model number in and it will come up with very cheap bearings thats where i get all my stock from. good luck £4.50p very cheap
Jan 06, 2008 | LG WM2077CW Laundry XL Front Load...
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
LG WM1812C Front Load Washer Logo
379 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
