Singer Futura Quartet FQ 4 Service Manual
This FQ 4 seems to be your product. A rose by any other name...
Service manuals are generally not available since they were intended only for technicians. You may be able to locate one by searching:
Make Model manual
or
Make Model service manual
SOURCE: Singer XL 100
I have an xl100 and would be willing to scan the manual and send it to you via email if you would like.
SOURCE: My singer futures XL 400 won't sew underneat
If the stitch problem is on top, it is a bobbin problem, and if it is on the bottom, then it is a problem with the top.
Try rethreading your machine completely. Make sure that the tension is set correctly.
If rethreading doesn't work, then try adjusting your tension, a little at a time, till you can find something that works.
If none of the above works, try changing your needle to a fresh one. And do your sample stitching on a medium weight fabric. Very sheer fabrics can be problematic without sewing machine problems. Good luck with your machine!
SOURCE: I'm looking for a Manuel and a start up cd for a xl 400 singer embroidering machine..
Singer has the manual for the Futura XL400 on the product site: http://www.singerco.com/products/2168/xl-400-futura . The direct link to the instruction manual is http://www.singerco.com/uploads/download/bbd749beb7151a637824d777a05c51b4fb50b0a4.pdf . There is also a quick start guide. Additional documentation and driver upgrade software is here: http://futura-support.com/products/xl-400 . Unfortunately, Singer doesn't provide replacement CDs if you lost the original one. According to the directions for the driver upgrade, you need the CD to install the upgrade.
The software packages are available for sale at Amazon and other vendors. Some CDs may be available on E-bay.
I hope the manual helps.
