Question about Canon PIXMA MP150 All-In-One InkJet Printer
Scanning I am scanning a white picture with black writing and it scans black with white writing. How do I switch this?
    President:
  • Canon Master
  • 1,447 Answers
It is problem setup scanning option
Posted on Sep 08, 2009
  • Sazeed Computer
    Sazeed Computer Sep 09, 2009
    you change scanning option select color picture if you are select black &white or grayscale
Scan color pictures
Does this problem happen when scanning either from the scanner glass or the automatic document feeder? Does this problem happen when scanning either from the computer using the Lexmark software or scanning using the Scan button on the printer operator panel? This will help me understand what might be causing this problem.
Feb 12, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
TO SCAN MY PICTURE
I right click on the scanned document to get the "picture toolbar"/select "picture control"/uncheck "automatic" and check "black & white"/print. Then can scan
May 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Images scan black via flatbed or auto feed
Check your software settings, Try Auto Brightness for scanning a white sheet.
S. Mohan
Nov 06, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Scanner only scanning in Black and White
well as i know there is a selection when u r scanning asking u to scan either in black & white or color
did u check that? maybe its switched to the black and white option
Jun 29, 2008 | Canon PIXMA MP470 All-in-One Printer
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
May 23, 2008 | Audio Players & Recorders
Curtis progressive scan DVD player 1071
your not using progresive scan out are u change that back to regual
Feb 06, 2008 | Curtis Progressive Scan DVD Player 1056
Scanning instructions for a Canon Imagerunner 6570 multifunctional copier
My Canon 6570 will scan to my computer perectly fine. When I try to scan a colored picture, it comes out Black and white!
Why? Please help!!
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
HP psc 1210 all in one
When you scan a picture or document try placing some white paper over the picture or document AND more importantly, cover the glass in a manner such that you have all the glass covered. That should solve your scanning issue. If it does not solve the problem, write back, including what happened when you tried the suggestion. Like I always say, try the easiest solution first, and then progress to the next step. Good luck. rey
Oct 24, 2007 | HP PSC 1210 All-In-One InkJet Printer
Black and White picture
Are you using component cables? If so, there is a switch in the back. Switch it to p-scan (progresive scan) It worked for me.
Nov 24, 2006 | GE GTD120 System
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
